Opening LE 7.1 Sessions on LE 6.x
I wanted to know if there was a way to import work that was done on a PT 7 session to a PT 6.4 session. My work computer uses PT 6.4 and my home is PT 7. I realized that whenever i opened a PT 6.4 session on PT 7 and saved it, it would make a PT 7 session file. However all the work I did on PT 7 would not open on PT 6, only the PT 6 session would open and the work that i did would obviously not be there. So if there is anyway to take my work that is done in PT 7 session and move it to a PT 6.4 session i would greatly appreciate it. Thanx!!
Re: Opening LE 7.1 Sessions on LE 6.x
Pro Tools Menus>File>Save Copy In and select from the drop down list what Pro Tools Session type you want.
filosofem |
Thank you very much...work perfectly!
