Avid Pro Audio Community (https://duc.avid.com/index.php)
-   003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) (https://duc.avid.com/forumdisplay.php?f=17)
-   -   Presonus Tube Pre and 002r (https://duc.avid.com/showthread.php?t=104134)
Joe Evans 04-24-2004 01:08 PM
I have a Presonus TubePre and an 002r. I have run an XLR to 1/4" TRS cable from the Pre to the 002r. Does anyone know if I should set the 002r input to +4 or -10? Either way seems to get extreme results, but I would like to get the best S/N ratio by matching the out and in as close as possible. I can't find the info in the TubePre manual or on the Presonus web site. Thanks.
--joe
Cliffy_Boy 04-24-2004 01:30 PM
Re: Presonus Tube Pre and 002r
If you don't overload at +4, then I would keep that setting. +4 gear going into -10 will be too loud. -10 going into +4 will be too soft.
Joe Evans 04-24-2004 02:27 PM
Thanks. The extremes I mentioned was that it was very loud (almost no gain from the pre) at +4 and had to be turned to a very high level at -10 to get a decent signal. I think I should stay at +4 and just keep the gain very low. Does thaat diminish the sound of the pre being injected into the signal maybe? I am running a Rode NT1-A into the pre and it threw me off having to keep the level that low.
Thanks Cliffy_Boy!
--joe
