Using Reason Adapted 2.5 with Pro Tools 6.9.2 MBox
Okay-
So I recently bought a mac with Tiger 10.4 on it and installed ProTools for my MBox. I then had to upgrade to 6.9.2 because the packaged software was not compatible. Then I installed Reason 2.5 adapted for Digidesign, and tried to run redrum through MBOX hardware outputs. The sound output was very clunky as well as the software, and when I tried to quit my computer froze up. I ran the program several more times.....same thing happened. I then switched the output to my internal audio card and everything worked perfect....so the problem must lie in the MBox....I've tried a number of things to try and fix the problem but have found failure and frustration. Can someone help????? PLEASE!!! -mike |
Re: Using Reason Adapted 2.5 with Pro Tools 6.9.2 MBox
What mac are you using?
