Bounce Handler cant keep up(-9132)
Please anyone ,in laymans terms,explain why and how to fix this problem I cannot get arouund? 512MB , 80GB, Pentium 4 , 1400MHz, 1.39GHz ,PTLE6.1.1 , Digi002R,firewire,windows xp
Re: Bounce Handler cant keep up(-9132)
Just got the same freaking problem!
thank you.I was able to bounce prior to a week ago.kinda of a pain in the ass to bounce that way.
Wow that sucks! I'll try it but what if we have a session that is 32 tracks and can't create another track?
Here's what I'd do:
Save three copies of your project, ORIGINAL.PTS, 31-AUX.PTS, and ADD-AUX.PTS. Leave ORIGINAL.PTS as is, as it will be your back-up should all go wrong. Open up 31-AUX.PTS, and delete enough audio tracks to be able to use the work-around mentioned in the other thread. Then, open ADD-AUX.PTS and delete all of the audio track aside from the ones you deleted previously to allow the work-around. Import the stereo track you exported from 31-AUX.PTS, and then use the work-around techique to make one final stereo track that includes the remaining tracks. Export the resulting track and you're set. Hope that works out for you! Rob |
