Timecode question...basic
So...somebody sends me a Hi Res mp4, I import into PT HD9, do my thing and then I'm going to send back a Stereo Wav for them. Is Timecode automatically imbedded in the file or....what do I need to do?
Thanks!~ |
Re: Timecode question...basic
x Picture timecode has to be added manually. I prefer it burned into the image.
x ProTools might have trouble opening .mp4 files. Try adding the mpeg stream to a .mov container instead before adding to ProTools. x To embed timecode into the exported audio of ProTools I usually go to File>Export>*AAF/OMF… I bet there are other ways too. The answers above might help you. But I am not that sure about what you're asking. Care to elaborate? |
TC is not embedded. There's a timestamp, but I'm not sure how much worth this is outside PT.
I'd either insert a "beep" two seconds before the first frame of action, or you start the mix with the first frame of action. However, I always inform the recipient where my file starts. That way there's no room for confusion. |
A Broadcast wav file has Timecode that is read by Avid at least.
FWIW for an export like this I make sure I use the same start point for the export as the original MP4. This allows the video editor to use the TC if they can or edit my mix into their timeline at the same point as they originally exported the MP4 from. Andrew |
