PT10 any improvement for composers?
Lots of great stuff in PT10.
The eventual demise of RTAS won't be causing any heartbreak I suspect. But for us composer engineer types are there any improvements in VI implementation in PT10? If I go to PT10 can I stop using VEP to host all my VI plugs? Can I run the mammoth VI sessions I run every day just in PT10? Or do we wait until RTAS is dead a buried and whatever replaces it is sorted out? Any compelling "composer centric" reasons to spend a thousand dollars? |
Re: PT10 any improvement for composers?
No specific VI performance enhancements and, no, I don't think you can get rid of VEP yet.
While there may be performance improvements to how well VI's work in Pro Tools 10, they would only be due to 'secondary factors' like use of the Disk Cache for RAM (thus allowing possibly more RAM for VI's), fewer out of memory errors (fewer fade files using up RAM) and so on. In my testing, the improvements are only marginal in the grand scheme of things. |
Thanks for the straight answer.
I hope you guys have thick skin. There seems to be a fight brewing. |
Very disappointing to say the least.
I moved to Cubase recently for all my VI stuff and there is simply no way Avid could catch up now. That being said Cubase IMHO SUCKS for audio work but I can easily get those frozen VI tracks into PT in no time if I'm doing ODs. I'm not down on Avid for this decision but VST and AU for VIs are so superior to the AVID format it really makes no sense for them to develop that. This was especially obvious when they dropped development on their "air instruments" division. So stop hoping for PT to become a composers tool. I waited 10 years and it ain't their priority. |
FYI - there is nothing inherently 'superior' about AU or VST. In fact, RTAS functionality with regard to control surfaces, inter-application communication, etc. has always been superior. The performance aspect with regard to VI's is more due to the DAW engine than anything - and that's the part that we still have to work on. |
Digitech,
Isn't AAX the main part of that? Along with the transition to 64 bit? Thanks |
