BNeoa_Utils::FindAsset failed in workspace
I'm trying to search and calculate overviews in PT8 (just upgraded).
Some of my files won't calculate overviews, the contextual menu option is grayed out and Pro Tools throws a: BNeoa_Utils::FindAsset failed! message. Additionally, the workspace is really slow. Doing a search or auditioning a file typically takes 10-20 seconds before anything happens. I've removed the Digidesign Databases folder on my audio drive (D:) no difference. PT8.0 / Win XP sp3 |
Re: BNeoa_Utils::FindAsset failed in workspace
try hiding your workspace behind other application's window when it starts to search. does it help? |
That seems to help.
It definitely helps the audition of sound files once I have my search results... Not sure how related this is to the FindAsset failure... |
I just discovered another thing, which is pretty crucial to reproducing this fault:
1. Open a workspace window 2. Browse to a HD with some audio files. 3. Search for some of them, eg "punch" 4. Right click to create waveforms => FindAsset failed. My auditioning speed with normal browsing is fine, but as soon as I have done a search, everything goes slow and screwy.... Shame really, considering search and audition are the main functions I use in the workspace. |
I discovered that the slowness is triggered by resizing the browser window - especially by setting and recalling browser window configuration presets.
If I avoid presets, and am very careful when resizing the window, I can eliminate the slowness bug from appearing, but I still get the FindAsset failure and cannot generate waveforms from selected files in search results. |
I'm also getting this problem:
I'm on PT8 cs2, LE, not m-powered. I'm trying to audition some garageband loops in the browser. I performed a search (eg shaker) and then tried to click the drop down menu to change the playback options. ERROR!! Not to mention, when I have finally found a loop, and try to drag it into the session, I get the wheel of death and it takes 5 minutes to import a tiny file! Adam |
Try to select all files in a map in the Workspace,
Press right mouse and click " calculate waveform " After the task is finished you should'nt get the message any more.. cheers |
thanks dude i'll try that
