Major dae error help -9073 and -9473
hey everyone i have been in a slight situation the past few months trying to really figure this out but i cant, every time I'm in a mix of a song i get these errors like 20 min into the session that first reads DAE error -9073, something about the DAE engine is too slow or something like that, then when i use elastic properties i get another error that's is error number -9473 it has something to do about elastic property i don't recall exactly the error information but can someone please help me!!!
I'm running on a Intel mac with a 003, control 24, pro tools 9.1 with operating system leopard |
Re: Major dae error help -9073 and -9473
Are you on Leopard 10.5 or Snow Leopard 10.6?
Where's your hard-drive? You shouldn't be using the internal system drive for audio. You need an external drive... and NOT USB. Must be Firewire or better.
10.6.? if click the Apple in the upper right and About This Mac, it will tell you the exact version.
What brand/model internal hard drive is your secondary drive? Is it 7200RPM? How many GB's is the capacity and how many GB's are available? When was the last time you cleaned off and reformatted it? Have you tried to record onto one of the other 2 "non-System" drives to see if they worked any better? Have you ever run with just 2GB of RAM, just to see if maybe you have a bad stick of RAM? That happened to me once and it kicked off error after error.. 2GB ran smoother than 6GB with the bad stick. I slowly rotated the sticks around until I found the combination that singled out the bad stick. |
