How do you increase the volume on a click track?
Is it possible? Thanks! PT 7.4 here.
Re: How do you increase the volume on a click track?
Push the fader up. If that's not enough, open the click plugin and push those sliders up. If that's not enough, AUX send to another AUX track and turn that up(adding a an AUX send and return will double the volume if all settings are the same). Personally, I have never needed to push the click track fader past +6. Usually, I leave it at -0 and add a send to push more to the drummer's headphones.
Thank you very much!
try turning other stuff down first. protect your ears man.
