Playlist malposition/mismatch
2 Attachment(s)
Hi, recently I had this problem which I never met before.
Here is the thing, I saved current session as a new session, and transfer to another MAC by hard drive. When I open it on my new MAC, some clips are not goes to the same location as the previous session. Especially the playlist clips. For example, my MAIN-L playlist got a clip named MAIN-L 1 at exactly the session start which is 00:00:00:00. But when I open the new session on my new MAC, it goes to 01:00:00:00 for example, and it should be under my Marker 1 goes to my Marker 5. seems like 30% of my playlist clips has this malposition issue. The previous session including a video channel on the new Mac Pro, so I was wondering if is the timecode or frame caused this problem? I did my back up everyday, so I got multiple sessions including audio files. Maybe is because the new session link to other session folder audio files caused the mismatch/malposition? The following picture shows one of the problems. As you can see, my Bass channel's clips goes to other channel's playlist. And when I import the same session again there is not mismatch at all. https://duc.avid.com/attachment.php?...1&d=1638865433 https://duc.avid.com/attachment.php?...1&d=1638865450 Anyone got the same issue like this? Thank you! |
