master Fader and L3 Multimaximizer
Hi Everyone, I am new with pro tools so I would really apreciate a little help with this,
I was reading the manual for the L3 Multimaximizer and there is something there that confused me, what do they mean by saying to insert the L3 after the master fader, I thought the master fader was the last track on a session, could someone please clarify this for me. Thank you |
Re: master Fader and L3 Multimaximizer
Create a new track (Ctrl-shift-N). Select 'stereo' and choose 'master fader' from the drop down list. This will act as your main fader for the entire session - any effects you put here (like the L3 or metering/analysis plug ins) will have a global effect on the session. Also any fade outs or volume changes made here will be global.
One caveat: Please don't overuse the L3! Use it musically and not just to slam the levels! Thanks! Hope that helps... Tom |
The master fader is like a global fader for the whole song. Just as you see on any analog board, there will be submasters and then a master. In Pro Tools you will need to create the master fader. You can add plug ins to the master fader to finalize and shape your mix, but only if you intend to have a final mixdown of the song.
In many cases people will not use any mastering plug ins on the master fader just like the L3, because the mix with just a touch of compression (maybe) can then be taken to another specialized studio that applies the final touches to the song. The process of finalizing the song is called mastering. This is if you want to follow the right process. But you can have a good final mix of your tunes if you use the mastering plugs. If you want to use it, you can definitely try. From the waves info. it may not make sense literatelly, but just add it on the inserts of the master fader. If you use more than one, start placing your plugins from top to bottom, in the master fader the L3 should be the last one, all the way at the bottom. http://www.waves.com/Content.aspx?id=3173 I don't know if you have seen it but check out the L3-16 tutorial. |
Thank you very much for your reply, your response cleared everything up for me again thank you
