Multiple Hardware Setup, a solution
I was reading
Importing I/O setups It gave me an idea, why not make another AppleScript Studio application that will backup different version of the DigiSetup.OSX file and reload them. I just finished the V2.0 of of my other application (the delete digi pref and database), so i had some free time. I made this ProTools Multi Hardware Setup.app I can now easily save multiple Hardware setup. It will not create an I/O setup file to go along with the DigiSetup.OSX, so don't forget to export one if you need it. Use it with caution, as it cannot tell the difference between a video file and a DigiSetup.OSX file. JC P.S. I made it a Donation Ware |
Re: Multiple Hardware Setup, a solution
Thanks JC Chris |
Just gave this a quick test and it worked a treat! i only tested by changing a few outputs! i assume it also does the +4 and -10 inputs and outputs and the input trims etc? sorry i was just leaving the studio and didn't have time to do a more detailed check! Will it always have to be used when PT is closed? Congratulation you have done what we've been asking Digi to do for ages!! Now can you fix the graphics freeze bug and make Danny a happy man! Chris |
JC |
Your utility protools multi hardware setup is FANTASTIC but it does not work in OS 10.7 :eek:
any chance of an update? :D thanks |
