H/w Buffer Check Question
Does anyone one know if their is a configuration in the actual computer itself that may be causing these buffer changes. I have brand new hard drives and the entire system has been checked and cleaned. Is there anything in the pro tools or the actual computer?? It makes me lower from 1024 and at 512 it says to raise it. It also sometimes doesnt finish bouncing, sometimes. If there are any ideas or things i can do to try let me know. Thank you!
Re: H/w Buffer Check Question
sandra report
As SW REC says, we need a sandra report. They're many reasons for this particular error, but one thing you can do is uninstall PT, Do all the optimizations that AVID has provided above in the links, then reinstall PT and see if that helps. This is only one possible problem and solution to this error code. To help you find sandra, Click Here.
Sandra Report
Model: XFX MG-63MI-7159
Workgroup: WORKGROUP Host Name: bz User: BtotheZ < Processor > Model: Intel(R) Core(TM)2 CPU E8400 @ 3.00GHz Speed: 3GHz Cores per Processor: 2 Unit(s) Threads per Core: 1 Unit(s) Type: Dual-Core Integrated Data Cache: 2x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size L2 On-board Cache: 6MB, ECC, Synchronous, ATC, 24-way, 64 byte line size, 2 threads sharing < Computer > Mainboard: XFX MG-63MI-7159 BIOS: AMI V1.2 04/23/2008 Bus(es): ISA X-Bus PCI PCIe IMB USB FireWire/1394 i2c/ SMBus Multi-Processor (MP) Support: No Multi-Processor Advanced PIC (:Yes Total Memory: 1.88GB < Chipset > Model: nVidia MCP73 Host Bridge Front Side Bus Speed: 4x 333MHz (1.33GHz) < Memory Module(s) > Memory Module: Corsair CM2X1024-6400C5DHX 1GB DIMM DDR2 PC2- 6400U DDR2-800 (5-5-5-18 3-22-6-3) Memory Module: Corsair CM2X1024-6400C5DHX 1GB DIMM DDR2 PC2- 6400U DDR2-800 (5-5-5-18 3-22-6-3) < Video System > Video Adapter: NVIDIA GeForce 7150 / NVIDIA nForce 630i (2 PS3.0, 1 VS3.0, Integrated Graphics) < Graphics Processor > < Storage Devices > WDC WD5000AAKS-00A7B2 (500.1GB:466GB (C:) (E:) WDC WD5000AAKS-22V1A0 (500.1GB:466GB (F:) ATAPI iHAS422 8 (SATA150, :N/A (D:) AXV CD/DVD-ROM (SCSI, SCSI-2, :613MB (H:) < Logical Storage Devices > Hard Disk (C:): 100GB (NTFS) @ WDC WD5000AAKS-00A7B2 (500.1GB, SATA300, 3.5", 7200rpm, 16MB Cache) Storage (E:): 366GB (NTFS) @ WDC WD5000AAKS-00A7B2 (500.1GB, SATA300, 3.5", 7200rpm, 16MB Cache) Music (F:): 466GB (NTFS) @ WDC WD5000AAKS-22V1A0 (500.1GB, SATA300, 3.5", 7200rpm, 16MB Cache) Optical Drive (D:): N/A @ ATAPI iHAS422 8 (SATA150, DVD+-RW, CD-RW, 2MB Cache) Audio CD (H:): 0bytes (CDFS) @ AXV CD/DVD-ROM (SCSI, SCSI-2, DVD+-R, CD-R, 512kB Cache) < Peripherals > LPC Hub Controller 1: nVidia MCP73 LPC Bridge LPC Legacy Controller 1: ITE IT8718F Audio Device: MSI MCP73 High Definition Audio Audio Codec: Realtek Semiconductor 888 High Definition Audio Audio Codec: nVidia 8001h Serial Port(s): 1 Disk Controller: MSI MCP73 IDE Disk Controller: MSI MCP73 IDE USB Controller 1: MSI GeForce 7100/nForce 630i USB Controller 2: MSI GeForce 7100/nForce 630i FireWire/1394 Controller 1: ADS Technologies TSB43AB23 1394a-2000 OHCI PHY/link-layer Controller SMBus/i2c Controller 1: nVidia MCP5+ SMBus 1 SMBus/i2c Controller 2: nVidia MCP5+ SMBus 2 < Printers and Faxes > Printer: Microsoft Office Document Image Writer Driver (300x300, Colour) < Network Services > Network Adapter: TRENDnet TEW-421PC/TEW-423PI 802.11g Wireless Cardbus/PCI Adapter #2 - Packet Scheduler Miniport (Ethernet, 5.5Mbps) Wireless Adapter 1: TRENDnet TEW-421PC/TEW-423PI 802.11g Wireless Cardbus/PCI Adapter #2 - Packet Scheduler Miniport (802.11g (ERP), 5.5Mbps) < Power Management > Mains (AC) Line Status: On-Line < Operating System > Windows System: Microsoft Windows XP Professional 5.01.2600 (Service Pack 3) Platform Compliance: x86 <<< Processor Arithmetic >>> -------------------------------------------------------------------------------- < Benchmark Results > Aggregate Arithmetic Performan:23.15GOPS Dhrystone ALU: 24.37GIPS Whetstone iSSE3: 22GFLOPS Results Interpretation: Higher scores are better. < Performance vs. Speed > Aggregate Arithmetic Performan:7.72MOPS/MHz Dhrystone ALU: 8.12MIPS/MHz Whetstone iSSE3: 7.33MFLOPS/MHz Results Interpretation: Higher scores are better. < Performance vs. Power > Processor(s) Power: 39.62W Aggregate Arithmetic Performan:584.30MOPS/W Dhrystone ALU: 615.12MIPS/W Whetstone iSSE3: 555.02MFLOPS/W Results Interpretation: Higher scores are better. < Performance Test Status > Result ID: Intel(R) Core(TM)2 CPU E8400 @ 3.00GHz (2C, 3GHz, 6MB L2, 1.33GHz FSB) Platform Compliance: x86 NUMA Support: No SMP (Multi-Processor) Benchmar:Yes Total Test Threads: 2 Multi-Core Test: Yes Cores per Processor: 2 SMT (Multi-Threaded) Benchmark:No Processor Affinity: P0C0T0 P0C1T0 System Timer: 3GHz Number of Runs: 64000 / 640 < Processor > Model: Intel(R) Core(TM)2 CPU E8400 @ 3.00GHz Speed: 3GHz Peak Processing Performance (P:24GFLOPS Adjusted Peak Performance (APP:7.2WG Cores per Processor: 2 Unit(s) Type: Dual-Core Integrated Data Cache: 2x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size L2 On-board Cache: 6MB, ECC, Synchronous, ATC, 24-way, 64 byte line size, 2 threads sharing |
I'd start by doubling your RAM to 4GB with proper timings, as well as getting a dedicated graphics card and disabling the integrated graphics, then go from there!
I'd start with a new motherboard. You have an intel cpu with a non-intel chipset and that is usually a show-stopper. Integrated graphics are indeed another issue, and I agree that you need 4gb of RAM. I would really consider getting some new parts. A new socket 775 mobo with an intel chipset should not be a lot of cash. An inexpensive nVidia graphics card will suffice(mine was $37 for an MSI 7300LE). If possible, get 2 more 1gig sticks of the exact same RAM(mis-matched RAM is not a good idea). If you can't match the RAM, I would buy 2x2gb sticks. The old parts would still be fine for an internet machine. Before you do any of this, look up your old motherboard and make sure its a socket 775. If it IS, then you might consider squeezing the wallet a bit and getting a new cpu as well(a Q9450 or 9550 would be a nice step up on a budget).
Thank you for your help guys!!! Muchly appreciated!!!
But with the ATI card, what kind of problems were popping up? Also, are there any other nVidia cards you can recommend for dual screens in that price range? Yours is discontinued and the ones Avid tested are too expensive! |
