Pro tools le 7.3 and Reason 3.0 Help Please!!! Help!!!!!
Ok im using Reason 3.0 in Pro Tools 7.3 with rewire. I have alot of questions. First question is, Can I create a Instrumental or Beat in Reason then send it to Pro Tools and mix the sounds individually? An example, have all my sounds in redrum separated in pro tools by kick drum, snare drum, clap, hi hat, etc. with out having to play it out in pro tools?
Also How do I create a beat and Reason and then send it to Pro tools to mix? Or should I create it in Pro tools through rewire and just play it out? Im wondering because i like using the redrum set up, but would like to just copy it in pro tools without have to record out the drum, hi hat, clap, etc. please help!! thanks, dennis |
Re: Pro tools le 7.3 and Reason 3.0 Help Please!!! Help!!!!!
Personally, I'd Export an SMF of the performance and route back.
filosofem |
sorry im new to this whats an SMF?
and what do you mean and how?
overall i just want to make a beat and mix and master it in pro tools.. |
Sure, Standard MIDI File (SMF).
Pro Tools Accelerated Videos - Reason Adapted (Part 1) – Setting up Reason Adapted with Pro Tools -------------------------------------- - Reason Adapted (Part 2) – Recording Reason tracks into Pro Tools ReDrum - Note the principle is the same. filosofem |
huh..lol..i kinda understand it but i think i need to watch the video again.. so i guess to record the redrum i just need to select a instrument track and enable and record it? no need to replay if i dont need to right?
thanks for the help dennis |
Only if it's going to Audio. If not you'll need to export an SMF.
filosofem |
how would i do that?
Audio or SMF?
filosofem |
both, but im assuming audio you just create an audio track for that and set the correct inputs right?
