No Sound Out Of PT???
Hello.
This is a very odd occurrence that's been happening for past few days. My system is MAC/Intel Pro Tools HD-9 System with 6 192s clocked by Big Ben with HEDD192 as master clock) and ICON . The problem started when a week ago few times I would open Pro Tools at the beginning of the day only seeing 5 out of 6 devices(192s). Had to restart it then it goes to full 6. That was a week ago. Few days ago, I open PT see 5, so I restart and still 5. No sound would come out of converters or get registered on meters of 192. Where I see it on meters in Pro Tools software. Tried restarting it few times, trashing preferences, switching sample rates. Finally, after a few hours sound came back on. Next day same thing, accept now sound doesn't come back. Tried to find if its one of the converts (192) is bad. Thought I singled out one, disconnected. Ok everything came back on. Next day same thing, even with the disconnected 192 same problem No Sounds or audio on meters of 192s. The weird thing is after about 2 hours the sound comes back.... Any ideas. Thanks. |
Re: No Sound Out Of PT???
Sounds like a heat related connection problem? I would try reseating all the cards and connections and give everything a good clean and use a anti dust air spray to get all dust off the connections then clean with contact cleaner. I would also try any trouble shooting using only one interface and card and try to isolate if it's one specific cable, card or interface causing it. Chris |
