Ran out of CPU power AAE -9173
Only other program running is Mail.
2.6 GHz i7 16 GB DDR3 RAM Am I doing something wrong? I'm new here. |
Re: Ran out of CPU power AAE -9173
NO, you are not doing anything wrong - for what we know .. which is not too much .. can you provide some more information please !! version of PT, what you do to make this Behavior happen ... that sort of thing thank you john |
I have Pro Tools 2019.12. I have these tracks total. Piano Buss -Piano T1 - VI, Comp, EQ -Piano T1 LH - VI, Comp, EQ -Piano T1 RH - VI, Comp, EQ -Piano Verb - Comp, Verb, EQ -Piano DLA - Comp, Delay, EQ Vox Buss -Lead Vox - Waves Tune Live -BG Vox - Nothing -BG Vox - Nothing Mix Buss Master When I hit space bar or play, it happens every time, even when I had one track done. |
Pro Tools 2019.12 I have a piano buss with 5 tracks in it, a vox buss that isn't being used yet, a mix buss, and a master. Mix has some compression and eq on it. It happened even when I had 2 tracks or on just about anything. I just hit space bar or play and it happens almost every time. |
Piano Bus with 5 Tracks .. more info please ?? is this a virtual instrument or audio ?? Buffer Settings ?? 32,64,128, ?? and while recording these VI's ... right !! |
