Strange Behaviour Send Faders
Anyone know this one:
Protools working fine...but only when i want to change the send faders the faders seems to very slow...working with mouse.... very annoying especially when I want to write automation with mouse...there is no additional fader hardware... This strange behaviour is only with the send faders not the channel faders those works fine, even dthe aux faders,master faders.... Setup: Macbook Pro Retina 10.9.3 Magma 3T with 1HDX card Protools 11.1.3 HD Omni i/o HD i/o Thunderbolt display Any one any idea? |
Re: Strange Behaviour Send Faders
no one?
Wierd, trashing prefs probably didn't help huh?
Drop back a version and see if the problem goes away.... |
Hi guys thanks for your reply....
I understand that writing automation in the edit window is much easier than edit the fader up and down in the mix window... But during mix when I want to give a bit more reverb or an effect send, the its pretty annoying when you move the mouse but the fader comes later up or down....some times when I make a fast move it takes a sec to com to the right position... And the most strange is that this is only on the sends faders:confused: |
Also, is it just in sends expanded view in the mix window (small faders only) or does it still happen when you open a big and fader popup window?
I have to check that the sends are not expanded view. Wireless mous, apple Magic Mouse ... There must be something, I'd did never had this before. Weird is it's only when I click the sends then the floating fader appears when I want to move it has a slow response, I think the sound goes the way I move the mouse so that seems to be on time...
Then that sounds like the graphics
Any idea what I can do about it
