Apogee PSX-100
How does one hook up an Apogee PSX-100 to the 001?
Thanks! |
Re: Apogee PSX-100
connect your analog cable to the analog inputs of the psx and then adat cable straight to the adat input of the digi audio card in your mac. make sure you select adat optical in pt le . i think its under setups- hardware.
Re: Apogee PSX-100
So the OO1 box (hardware) is bypassed all together?
Thanks! |
Re: Apogee PSX-100
Yes, if you use the ADAT optical I/O's. The PSX-100 also has spdif I/O, and you could hook that up to the 001's I/O box if you want to.
Definitely use the PSX-100's D/A as well as the A/D - it is excellent! Jeff D. |
Re: Apogee PSX-100
when you use the adat optical and the digi 001 the 001 is NOT bypassed. you can record 18 tracks simultaneously.
Re: Apogee PSX-100
Skip the soft limit , it aint 2" tape and dont fall into thinking slammin it will sound like it either http://www.digidesign.com/ubb/images/icons/shocked.gif It's Damn usefull for 'gonzo' signals though!
http://www.digidesign.com/ubb/images/icons/smile.gif Apogee Rocks big time all the time. Jules [This message has been edited by Jules (edited January 11, 2001).] |
