Eucon network connection not found
This error message appears every time I try to load the Eucontrol software. I've repaired disk permissions, changed the permissions on the lib folder, made all other network settings inactive, and reinstalled the software several times, but with no luck.
My usb hub with my ethernet port broke recently, so I had to order a new one. The new hub requires drivers which I had to download. Is it possible that the new hub is causing a conflict with the Ethernet port and Eucon? The software worked fine before using this new hub. I'm running an Avid S1 with Logic Pro X on a MacBook Pro 2.4 GHz 8-core Intel i9 with MacOS Catalina Any help would be amazing! |
Re: Eucon network connection not found
Hi. Did you find a resolution for this? I am having the same issue.
