#7204 errors on HTDM plug-ins
all of the sudden i get these 7204 errors all the time when i try to open a HTDM plugin. (not enough free dsp) although i have 10 free slots. this just started happening last night. any ideas?
HD2 on tiger |
Re: #7204 errors on HTDM plug-ins
HTDM (host-TDM) uses your computer cpu for its processing power and also as it is htdm it will not show it usage in the cpu meter! so i would say you are probably at the top of your available cpu processing power and that's why you are getting eror messages. Chris |
HTDM plug-ins (Stream Manager) are limited to using one single DSP chip -- if the chip becomes full.. even if you have more available chips... will not be able to instantiate any more HTDM plug-ins. In System Usage if the Stream Manager is full... you can't add any more HTDM plug-ins.
Rail |
digi, please make htdm better! ie. more stable, ability to use more instances.
