crash moving mix window while playing
hi,
strange thing: i have two screens connected to my MBP. everytime i try to move the mix window on the right screen while playing on the left screen (edit window) PT crashes - no more action possible, not even alt+apple+esc, only chance brutal switch off of the computer. any ideas? thanx in advance schoen MBP 2,66 / 4 GB RAM / MAC OS 10.5.8 / PT 8.0.1 LE / MBOX 2 |
Re: crash moving mix window while playing
... any idea?!
... bringing this up again, hoping for help :confused:
Would you mind describing your workflow?
Any troubleshooting steps? |
thanks for the reaction! what do you mean with workflow apart from the things i described above?
You say you have 2 screens connected - how are they connected, exactly, given that the MBP only has a single DVI output?
the second screen (just for the mixing window) runs via USB and a Kensington Dual Monitor Adapter, no problems til now apart from the one described above
Look after in your log files, what caused the crash. It can be some os related things, which might be resolved with onyx. (free app)
You can access your logs from the system profiler utility. TD |
You're better off running video through the cardbus slot, if you're really sold on using the extra monitor. It will be far more stable, and will steal less system resources. A decent video card for the slot will be a bit more expensive, but the difference in performance/stability will be quite noticeable. |
I'm with Dism on this one - USB for video is probably fine for everyday stuff (email, word processing, etc.), but I wouldn't rely on it for system taxing apps like Pro Tools.
