Windows 7 mbox2 PTLE problem
I`m getting a sporatic crackle when in record mode. I don`t have the external firewire etc. hard drive and was wonder if this will fix my problem or if i can save the money.
Pretty sure computer is up to par in terms of RAM etc. |
Re: Windows 7 mbox2 PTLE problem
There could be many, many reasons for a "crackle" and recording to the system drive is definitely one of them. |
I am also experiencing random crackles and pops in 8.0.4 when in record mode. This happens even when listening to track output with PT stopped
(ie track is armed) As far as I'm aware there is nothing being written to the HDD in this situation, so that eliminates the HDD as a cause. I am using a USB 2.0 7200rpm external drive that has always worked well in PT7.4 The problem only started with Windows 7 and 8.0.4 which I have installed on a new laptop using all the Digi optimisations etc. Everything else is working fine, and I can play back older sessions recorded on the previous laptop with no noises whatsoever! Any help or suggestions would be much appreciated... Basic specs: Toshiba A500 laptop Intel Core i5 520M CPU 2.53Ghz with Turbo Boost 4Gb RAM Maxtor USB 2.0 120Gb 7200 rpm HDD (external) nVidea GT330M 1Gb graphics |
I have been experiencing issues with buffer settings below 256 on my MBox Mini, but my 002r doesn't have the same issues on the same system. I'm still investigating (when I get time). |
Thanks for the quick response Spkguitar...I will check my reference guide as you suggest. The same HDD has worked fine with two different laptops and my desktop, with PT 6 LE and PT7 LE, so I naturally assumed I would have no problems with PT8! I might add my sessions are not too demanding with track count/plugins etc (maybe ten tracks at most)
It's actually my daughters new laptop and I have'nt got it here right now, but I'm pretty sure it was running the default buffer setting (512 samples from memory) I am using mBox2 and have substituted a brand new one (and USB lead) but no change. I might add that the crackles and pops only happen to audio input fed to the mBox mic/line ports. All recording/playback of the Xpand2 plugin for example is noise free. Thanks again... |
SiSoftware Sandra Computer Model : Lenovo 4444CTO Workgroup : WORKGROUP Host Name : Ryan-THINK User : Ryan Processor Model : Intel(R) Core(TM) i3 CPU M 330 @ 2.13GHz Speed : 2.13GHz Cores per Processor : 2 Unit(s) Threads per Core : 2 Unit(s) Type : Dual-Core Integrated Data Cache : 2x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size, 2 threads sharing L2 On-board Cache : 2x 256kB, ECC, Synchronous, ATC, 8-way, 64 byte line size, 2 threads sharing L3 On-board Cache : 3MB, ECC, Synchronous, ATC, 12-way, Exclusive, 64 byte line size, 4 threads sharing Computer Mainboard : Lenovo 4444CTO BIOS : Lenovo 81ET28WW (1.04 ) 03/26/2010 Bus(es) : X-Bus PCI PCIe IMB USB i2c/SMBus Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : Yes Total Memory : 1.87GB Chipset Model : Lenovo Auburndale/Havendale DRAM Controller Front Side Bus Speed : 1x 133MHz (133MHz) Memory Module(s) Memory Module : Elpida EBJ21UE8BDS0-DJ-F 2GB DDR3 SO-DIMM PC3-10700S DDR3-1334 (9-9-9-25 4-34-10-5) Memory Module Memory Module Memory Module Video System Video Adapter : Intel(R) Graphics Media Accelerator HD (SM4.0, 64MB, PCI) Graphics Processor Storage Devices HITACHI HTS725016A9A364 (160GB, SATA300, 2.5", 7200rpm, NCQ, 15MB Cache) : 149GB (C:) (Q:) HL-DT-STDVDRAM GT30N (SATA150, DVD+-RW, CD-RW, 1MB Cache) : 3GB (D:) Logical Storage Devices SYSTEM_DRV : 1GB (NTFS) Ryan's (C:) : 138GB (NTFS) @ HITACHI HTS725016A9A364 (160GB, SATA300, 2.5", 7200rpm, NCQ, 15MB Cache) Recovery (Q:) : 10GB (NTFS) @ HITACHI HTS725016A9A364 (160GB, SATA300, 2.5", 7200rpm, NCQ, 15MB Cache) BUILD (D:) : 3GB (UDF) @ HL-DT-STDVDRAM GT30N (SATA150, DVD+-RW, CD-RW, 1MB Cache) Peripherals LPC Hub Controller 1 : Lenovo P55/PM55/3400 LPC Interface Controller LPC Legacy Controller 1 : Winbond W83687THF Audio Device : Lenovo P55/PM55/3400 High Definition Audio Audio Codec : Realtek Semiconductor High Definition Audio Disk Controller : Lenovo P55/PM55/3400 4 port SATA AHCI Controller USB Controller 1 : Lenovo P55/PM55/3400 USB2 Enhanced Host Controller USB Controller 2 : Lenovo P55/PM55/3400 USB2 Enhanced Host Controller SMBus/i2c Controller 1 : Intel 801xx/63xx SMBus Network Services Network Adapter : Realtek PCIe GBE Family Controller Wireless Adapter 1 : 11b/g/n Wireless LAN Mini-PCI Express Adapter II (802.11g (ERP), WEP n-bit, 36Mbps) Operating System Windows System : Microsoft Windows 7 Ultimate 6.01.7600 Platform Compliance : x86 Windows Experience Index Current System : 4.0 |
Those of you experiencing problems with Digidesign/Avid USB interfaces at lower buffer sizes, try changing the USB port. Quote:
From what I have seen posted so far to this forum with those using it are having problems. Quote:
First off, 2GB of RAM is pretty bare minimum these days. 4GB is standard, really. It should be pretty easy and cheap to upgrade to 4, but that is the least of your issues here. On-board graphics are not supported for use with Pro Tools. As you can see, your computer is only recognizing 1.87GB of the 2GB of RAM you have, because the on-board graphics hub is stealing memory. The fact that it is an extremely low 64MB hub doesn't help either. Honestly, this laptop is really not something I would even attempt to use seriously with Pro Tools. An i3 chipset, while new, is still considered the low end "economy" processor. Not a whole lot of grunt to it. Combined with barebones memory, on-board graphics, no FireWire controller or second hard drive... you might as well not even try to use Pro Tools on this laptop. |
damn, oh well thanks for help
Sadly, the i3 is the new Celeron and likely NOT a good choice for Pro Tools.
