Pro Tools 10, iLok, and university computer labs
Hello, I teach at a university and the staff that maintains the computer systems in the lab I teach out of is hesitant about installing iloks on the machines. What have other people done, and is there a way to authorize classroom systems like this without iloks? The iloks would certainly be stolen quickly.
Unfortunately there is talk of going back to 8, which I would like to avoid. Thanks for any input! |
Re: Pro Tools 10, Ilok, and university computer labs
One option here is to install the iLok internally in the computer.
Best approach is to get a cable that will connect to the USB connection points on the computer motherboard and ends in a normal USB socket. A cruder option is to plug a cable into a rear USB port and then feed that cable back insider the computer casing through a hole drilled in one of the back-plates. This is how we've a number of 'portable' USB devices protected from theft at the organisation for whom I work. |
Obviously if the lab is unsupervised then a thief can open a PC case, and that can be especially easy with some zero-tool designs. Some cases can be secured by a lock or cable, often the same cable used to secure the PC to the desk. Obviously all this is defeatable for a determined thief. You just want to make it easier than pushing one button or pulling one tab opens the case--I've heard of high-end graphics cards and memory DIMMs walking out of computer labs. An (even fake) security camera in the corner of larger/more valuable computer room might help. Make sure your keep track of all the iLoks and report any stolen. Darryl |
the above will work
the other option is to hav lock boxes that the USB cables run into and the box it bolted to the rack or wall. this lets one have access to the iloks if needed w/o having to open the computer up something like this on a bigger scale http://www.instructables.com/id/USB-Safe/#step1 or this http://www.findtheneedle.co.uk/compa...it-dongle-safe or you could try this IP server for USB dongles http://www.seh-technology.com/produc...le-server.html I work in a school with over a 100 system on ilok, were on PT10 and was so glad to get rid of the MBoxes |
We have over 100 Pro Tools stations at the school I work for in my day job. We use simple braided security wire with cable ferrules. Take a length of wire that will provide enough for a nice service loop, string the ilok thru one end, pull the wire thru the hole in the pedestal on iMacs or in the Kensington lock post on Mac Pros (or some other secure point - say a rack rail), then put both ends thru the ferrule and crimp. Haven't had one stolen this way, and - with how cheap they are to make - if we need to remove the ilok for service, a snip of the bolt cutters later we're good to go. And we don't need to go into the machine each time we need to service the loks (which is not very often). If the initial loop is long enough, we can get 3-4 uses from one length of wire. Simple, cheap, secure. One roll of wire may cost $100 or so (the ferrules cost pennies each), but that pales in comparison to the value of the locks. Hope this helps!
Nathan |
i have seen this very setup at our local audio tech school... seems very solid.!..
no need to stick iloks inside the box but i've seen that as well.. seems much cleaner solution just to use security wire... |
