Cable Question
This may be kind of a stupid question, but hey, this is what forums are for, right?
I have just set up my 002r with five synths, MIDI interface and a 01v/96 mixing board and outboard effects. Everything fits into a neat and tidy space, except I have a veritable SEA of cables running in back of my rack. I'd like to have all of my cables shortend to minimal lengths, thinking it might cut down on cable noise. (or at least make it look more ergonomic) The question is about balanced cables. Most manufacturers reccomend using balanced cables. All of my cables have only one black ring on the tip. Does this mean it is unbalanced? Should I change all of my cables so they are balanced? Any other things to consider when buying cables? |
Re: Cable Question
yes, unbalanced
Balanced cables have a tip-ring-sleeve connector pin 1-2-3 - + ground Balanced cables can help with noise and interference. The balanced cable is shielded by a foil wrapping. Better wire standards is one more thing to consider when buying cables. hear any noise? Buy the best cables you can afford, you will hear the difference |
Re: Cable Question
Hey thanks for the input.
I'll figure out how long each needs to be and then have them cut to that lenght, with quality cables and 1/4 inch jacks |
Re: Cable Question
If the output is unbalanced there is no use in using balanced cable. Most synths' outputs are unbalanced.
Fot getting rid of the cable mass you can use multi-pair cables (multicord / snake) |
Re: Cable Question
Unless the output of your synths are balanced, which is highly unlikely, you'll probably get more noise using balanced cabling, as you'll be floating the neutral, sonce it has no connection in an unbalanced connecteion.
If your cabling is under 15-18', you'll not have any problems. Keep them away from video monitors and AC. Cutting them to length is also nto recommended, as if you need to repatch, you now have a length issue. get yourself some wire ties to neaten things up, and you'll be fine. |
Re: Cable Question
Re: Cable Question
Wire ties can help. Cable lacing bars can help. But the suggestion about multipair cable is also excellent and usually what works best for me in wiring racks. http://www.markertek.com/MTStore/pro...Item=MG%2D2930 Is what I often use. For keeping things neat running from the rack to your gear or other parts of the room when you can't lay real cable troughs, I really like these fabric/velcro cable wraps/channels; easy to add new cables to, etc: http://www.markertek.com/MTStore/pro...seItem=FLX%2D1 D |
Re: Cable Question
i have all my synths (that are unballanced) connected by balanced cables. will this hurt my sound quality or affect my sound in any way? should i switch them to unbalanced? i know that balanced is trs, but how would a catalog describe unbalanced? thanxx for any help. *** just when i thought i was starting to know something!!!!!!
Re: Cable Question
Why did balanced cables exist ? They are used when long connections are needed, for example a mic on a stage and the FOH console in the audience. As you have three wires (+,-, and shield), when there is noise on the line, it will be cancelled (+-=0). Usually also, the levels are differents. If you can have a balanced connection with a short cable, in a studio or at the back of a full rack, normally you won't have noise problem because of other stuff.
A very good source for quality cables is Studiospares. |
Re: Cable Question
so it shouldnt make a difference, yes or no? i got kinda confused with what you wrote. i think you said the balanced cables are ok.
