M-Powered / LE compatibility?
Hi all --
I haven't been able to find this question answered on the forums elsewhere. According to Digi's site, M-Powered project files can be opened on an LE system. Does anyone know if the reverse is true? I'm in a situation where the studios I'v worked with are LE, and (potentially) I'd be M-Powered at home. Thanks in advance. |
Re: M-Powered / LE compatibility?
Bump
i've opened tdm sessions on my m-powered, so i would assume you could open le sessions. (it worked perfectly btw)
yes you can do so with no problems.
be careful with PT7 though as there is no backwards compatibility unless you "save session copy as" in a pt 6 format |
This is OT, but waxdart, is your name a Bill Hicks reference?
