Mbox mini recording
Ive been trying to use my mbox mini to record some tracks, but the problem is I cant figure out how to adjust the volume to the instrumental or to the verse I recorded. It always comes out with the beat being LOUD and the vocals being very weak. Btw, the beat im using is just an eminem intrumental. Is there a way to turn the instrumental down some, and my vocals up?
Re: Mbox mini recording
You should be able to adjust thier respective faders to balance your mix. Can you see the Mix Window?
Well now I can control the volume, but it dont let me do more then one verse, I load the instrumental, and then go to lay a track on audio 1 and the mic wont pick up anything when I try to record on audio 2. I did turn off record on audio one, and switched it to two, but I still dont get anything
Arimin,
Welcome new user Looks as if you are having a couple of different issues. I would strongly suggest to read the "Getting Started" guide that came with your system. That will clarify how to assign recording inputs to tracks/channels and how to select regions for manipulating automation or gain changes. best of luck, |
