Re: Audio from VIs on laptop to Pro Tools on another computer
Using Vienna Ensemble Pro 5 with Pro Tools 9, 10 and 11 (A most helpful and informative video, but I remove headphones for the first second – it’s just a bit too loud for me …) https://youtu.be/jGP7-bxPJXU Use a Desktop or Taskbar Shortcut to launch VSL’s 64-bit Server first – some also add VSL’s 32-bit Server for their favorite 32-bit VST & VSTi plugins – then launch Pro Tools Vienna Ensemble Pro and Pro Tools Multi-Channel Multi-Output Setup https://youtu.be/yd5ChozAys4 Setting up VE Pro on Mac: How to Use Vep 7 with a Slave and Master Computer https://youtu.be/BcwvPYbyICo (Different DAW, but useful VE Pro info) |
Quite interesting the setup for tweaking settings or anything on the slave computer using screenshare. |
Vienna Ensemble Pro 7 - Routing in Pro Tools
https://www.vsl.info/manuals/en/vep7...-for-pro-tools Vienna Ensemble Pro 7 - #2 Setup & Routing https://youtu.be/Ql9DvnmsXQA Vienna Ensemble Pro and Pro Tools Multi-Channel Multi-Output Setup https://youtu.be/yd5ChozAys4 VE Pro in Pro Tools Tutorial https://youtu.be/yXEXf3GNNM0 We no longer need an extra USB port for an eLicenser dongle – VSL have moved to iLok: FAQ: Licenses & iLok https://www.vsl.info/en/tutorials/faqs/licenses |
Damn, a great pile of info there, thanks unkJE.
Plus, Vienna Ensemble Pro helps with distributing the VI processing outside of Pro Tools. It takes some of the weight off of PT's shoulders. I use Omnisphere, Ivory, Trillian, Keyscape, Kontakt 6 based VI's with it. I ditched my slave machine (Mac 5.1) when I got the Mac Studio Ultra (MSU) - but I still use VEP in the MSU. Not sure if I need it for new sessions - but for all the pre MSU sessions it recalls all the old settings in the plugins hosted on VEP.
It's a very cool program Last I heard (I think) you got the Big Bang Orchestra with it. Not sure if that's till available. |
