Ignition Pack Code(s)
Still re-wetting my fingers ....
I've installed PT and the BombFactory stuff successfully (well, the codes were on the iLock ), but it's been eighteen months since I first installed this stuff and I'm confused about installing the other apps. The ignition pack contains several applications, such as Reason Adapted, BFD Lite and a few more. Do I need separate liscences for each? Also, I have this card that came with the Ignition Pack. On the bottom right there is a bar code with two sets of "code like" numbers at the top and another set at the bottom. Which of these is the activation code? |
Re: Ignition Pack Code(s)
Hey, fellas,
I'm still tyring to authorise Reason Adapted. Anyone know where to find the code? HELP!! |
Guy, You have a couple of methods of authorization methods depending on the ignition packs vintage. I'm quessing you have a card for the Ignition Pack with a master authorization code. Register/activate that code with Digi and they will drop a itemised list of the plugs, thier serials and download links into your "My Digi "account.
Older versions have the codes on each card |
for all the ignition pakege you will need to register at digi design with your no .
than you will get a no for all your plagins in the email send to you . than you will have to go to the plagin site and open acount and sine you no in thay will send you apass word for your plagin .this is moor or lees on all of them.ther are some that not like the other like the sinth that you wiil need to jast tipe it in .sory for my spelling. by uzi |
Thanx for the reply, man.
No need to apologise. I can see that English is not your native tongue, but I'm sure you are WAY better at English than I am at your language. What language do you speak? |
