Protools 10 HD software, different from PT10?
I noticed that I had some licenses in my ilok from when I got my Native system, they were for HD10. I installed them and now it boots up with the PTHD10 Splash screen. So for the last couple months I have been running my HD Native card with Protools 10, not Protools 10HD. I noticed that I have the input button now, is there anything else significant from the regular pt10 version I should know about? More importantly, is the processing and algorithms the same, in other words, does both software versions sound the same?
Thanks |
Re: Protools 10 HD software, different from PT10?
10 and 10HD Native user the same bus programing
HDX is the same programing but rendering using the HDX DSP old HD is different do to the old DSP chips in short nothing to worry about |
Something I just learned that if you have HD10 software you can use it as just PT10. Just under mac system prefs/sound don't select HDN card as your sound device or in my case HDX and I assume HD TDM. The only differences I can think of is latency, track count , voices and video features. If thats what you meant . The Ilok tells PT what your authorized to used. If you have HD on yur ILOK it will automatically load HD software unless you select a different sound option. But if it didn't say HD it wasn't. After using just PT then going HDN was it worth it. |
Can you import session data from other sessions on PT10? I thought that was an HD only feature as well..Also disk cache is HD only i thought..
Import session data is standard in PT9 and 10, I believe.
VCA groups and Trim automation are the ones I can think of
Import Session Data is the same for both "versions".
The main differences are: Surround Capability Fieldrecorder Workflow Trim automation VCA Groups and Faders Input monitoring Audio Processing is the same for HD or none HD Systems. Basstian |
Wanna sell your native copy of 10 ??? :D:eek::D
my screen name @gmail.com |
