Idiot Recording Question
So, I just was able to get Pro Tools reinstalled on my new laptop. I haven't used it for several months as I was waiting for the new system.
I loaded up one of my prior sessions and everything is fine, except for one small issue that my stupid pea brain can't seem to recall. I need to create the guitar track. I have other tracks on the session so I added a stereo Instrument track and set the input i/o to Eleven Rack and output to Mains. When I record enable the track I can hear the input through the monitor totally fine. However, when I actually switch the session into record, the sound from the guitar track is no longer audible nor does Pro Tools appear to be recording any of the input. I did a quick check of my user's guide. I am sure I am missing something totally stupid and I was hoping someone could quickly point what it is out before I have to invest a large amount of time in debugging the issue further. I would appreciate the advice from those more experienced that I! |
Re: Idiot Recording Question
Sorry I don't know the specifics of using Eleven Rack. I just think if you want to record an audio file of your guitar playing you need to create an audio track, not an instrument track. I don't know why you can hear the guitar on input with the instrument track, but that is normally for VI's triggered by midi. Please ignore if I didn't understand the question.
When I was typing the question I wondered the same thing.I switched it out for a stereo audio track and BINGO you are absolutely correct!
Thank you so much for the quick fix!! I do find it strange that an Instrument track isn't for an instrument but that is another discussion. Again thanks so much. |
Bashville looks to have nailed it.
I just tried setting up both an instrument track and an audio track with my Eleven rack. With the instrument track (which is presumably for midi) the meter does show some input but nothing is recorded. With the audio track all works as it should. Have you tried that? Chris OOPS... too late. :-) Posting at the same time, and lost by a whisker... The main thing is that it now works. |
In Pro Tools, at top of window select Track>Auto Input Monitoring (If it currently says Input Only Monitoring, click on it) Select Track again & you should see Auto input monitoring has been selected And I totally overlooked the track type lol. |
G |
Pro tools is complicated but not THAT complicated, once you get your head around a few concepts you will be off to the bloody races, sounds like your already on your way! |
