DIM control on D-Command not Working??
Apparently, I've messed something up on the D-Command.
The DIM button does not dim the monitors an longer. Sorry, I can't locate the D-Command manual to find out how to correct this. Any quick fix on this?? Thanks, |
Re: DIM control on D-Command not Working??
Did you check your Dim level control encoder setting ?
I'm not sure for D-command but on D-Control Dim Level sets level reduction ranges from –30 dB to 0 dB, in 1 dB steps. Maybe you touched the encoder by accident ? When the Dim encoder knob is touched, the monitor section display shows “Dim” and the gain reduction in dB. Hope this helps. Grz, Louis |
There is no Dim encoder on a D-Command. Press and hold the Dim button till the Dim value comes up in the Volume display then release it, you can then alter the dim amount with the main volume encoder, to exit press dim again.
Pete |
Hey Pete. Thanks,
You are correct. All better now. |
