is there a surround switcher/router?
Hi everyone!
We have 24mix plus surround setup with Pro Control. We need to find a 6-channel switcher/router so that we can monitor lay backs to DA98's in Conf mode. Are there any high quality switcher/router that you can simultaniously switch all 6 channels between different source machines? like 888 outputs and DA98 outputs? (Analog would be fine) Thanks |
Re: is there a surround switcher/router?
Try www.martinsound.com
They make a variety of monitoring switchers which are very flexible and can downmix from 5.1 to stereo or mono. The one we use is called a Multimax. Hope this helps. |
