Anyone use a CME UF8???
Hi, I'm using a CME UF8 and I've come to this forum because the CME forum doesn't answer my question, the CME manuals are useless and their support is worse. I don't know how to alter the range of the pitch bend wheel from its default of four semitones. Can anyone help?
Re: Anyone use a CME UF8???
hey quite frankly you wont get an answer here as its not pro tools related but i got one too, worst thing iv EVER bought. as its not a synth and just a controller i would of imagined you alter the parameters of the pitch wheel through the actual sound module be it soft or hard
Well, thanks for responding . . . I don't think it's the worst thing I've EVER bought, I mean those Sony cordless headphones were worse Why do you think it's so poor?
CME has a pretty bad reputation for both poor USB drivers and generally poor craftsmanship. Don't be surprised if all the black keys on your board start only broadcasting at velocity=127, that's generally the first thing to go, but other things might start falling apart before you even get that far. My main advice would be, once it's set up, don't ever move it, and definitely do not think of using for any kind of live gig situation, the jostling around of travel seems to trigger the disintegration more quickly than if you just leave it be.
Well, thanks for all the posts . . . I guess I need to figure out how to change the pitch bend in Miro Philharmonik . . .
