OT_Reason 2 error "Can not open ReWire2 System..."
somebody help me here.
I just got reason 2 and I installed it. everything went fine until I run the Reason. It keep's on giving me this error message "Can not open ReWire2 System. Please make sure you have the right ReWire version installed." I am not running it as a plugin I am running the aplication only. by the way I have Digi002, PTLE 5.3.2 and the ASIO drivers. please heeeelp me
pardon my stinkin' writtin' |
Re: OT_Reason 2 error "Can not open ReWire2 System..."
Reason 2.0 installed and ran without any problems on my system, which also already had 5.3.2 and Digi ASIO driver installed.
I then installed the free Reason 2.5 upgrade, and that worked correctly as well. If you have a full licensed Reason 2.0 package, you should get the free upgrade to 2.5 from Propellerhead - maybe installing that will clear up the problem (and you'll get a few interesting new effects.)
Quad 2.5 G5, 4.5G RAM |
You may have too many rewire.dll files on your system. Do a file search on all drives for rewire.dll and if you find multiple copies, remove all but one with the latest version. If you are afraid to delete the files, just change the name to something else like rewire.bak. I believe the only copy of that file should be under C:\Windows\System32 directory.
thanks bigbottombass
actually the ReWire.dll that was in c:\windows\system\ was the correct one (I found out that while looking the dates). PEACE And thanks alot
Cannot open PT9 Session in PT10 - ""could not complete the open sessions command..." | median | Pro Tools 10 | 5 | 10-01-2013 11:14 AM |
PT9 Session Troubles - "Bus Error" in "Main Thread" & Could not complete the Open... | tohmit | macOS | 5 | 03-23-2011 12:13 PM |
Cannot open session in Mpowered7.3 (created in 7.3 but gives "older version" error) | Krizaps | Pro Tools M-Powered (Mac) | 3 | 02-18-2011 12:31 AM |
PT 8.1 audio "hits" or "pops" when i open files from PT7... | djoeyd77 | Pro Tools TDM Systems (Mac) | 1 | 10-31-2009 03:59 AM |
Please advise on error msg-File not open (-38) while reading "ProTools.vdb" | willcw | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 02-06-2009 05:49 PM |
