Old 01-27-2001, 03:09 AM
3james 3james is offline
Default Kick drum mic techniques?
wondering if anybody would like to share their secrets in getting a killer studio kickdrum sound. I'm looking for BEEFY but keep on getting FLABBY !!!
Old 01-27-2001, 06:17 AM
Rams Boy Rams Boy is offline
Default Re: Kick drum mic techniques?
It could be the drum. My first rule for a good drum sound is to start with well tuned, good sounding drums. It's hard to make a crappy kit sound good.
After that, depending on the song I usually do 1 of 3 things.
1. D112 inside kick 2-3 inches from beater head. (Deeper sound)
2. Senn 421 inside kick 3-5 inches from beater head. (Tighter sound)
3.Add a U47fet outside the kick 1-3 feet away. This adds incredible body and clarity and fullness to the sound.But dosen't work for all songs.
Also a Beyer M88 works well in place of the 421 or D112.
[This message has been edited by Rams Boy (edited January 27, 2001).]
Old 01-27-2001, 07:11 AM
MMazurek MMazurek is offline
If you can, add to the above by covering the drum with a packing blanket. It reduces some leakage from toms/cymbals and isolates the kick a little more.
(really nice preamp/eq combo doesn't hurt either)
Old 01-27-2001, 07:22 AM
Sortasonic Sortasonic is offline
I've had great results with a Sennheiser e602 inside and Royer R-121 several feet out in front with some minimal EQ tweaks (usually high pass). But I agree with Rams Boy. You can argue about mic brands all day, but it really boils down to a good sounding drum and room. Once you have that, you're 90% of the way there. Honestly evaluate you're kit sound before you even put up a mic.
Old 01-27-2001, 07:51 AM
maxcap maxcap is offline
I read this in modern drummer.... try tuning the drum higher.
The theory being that you bring the low frequencies of the drum up to a pitch you are able to hear.
If the drum is tuned to low all you are going to hear is attack and not much of the drum.
Everyone in this room is wearing a suit, and don't kid yourselves Zappa
Old 01-27-2001, 06:56 PM
jeffjuliano jeffjuliano is offline
The Beyer M-88 is the best single kick mic I've ever used. I swear by it! It gets all the top end smack and all the "subby" lows we all love to feel in a kick drum. When avalible I submix the M-88 with a Nueman FET 47 in front of the kick about 6 inches out with a pop screen in front of it to keep the air from blowing out the diaphram. Keep in mind all of these toys don't make a bit of difference if the drum sounds lousy from the get go or you have a drummer with an inconsistant foot and a big attitude. I find the later situation to be more common these days.
Good Luck!
www.myspace.com/jeffjuliano
Old 01-27-2001, 07:42 PM
Fred Cannons Fred Cannons is offline
Try a Shure Beta 52 (on a shock mount preferably) about 12" away from the batter head and off-center - about 3" from the shell. I find the Focusrite Red 1 a superb mic pre for kick drum. Front head makes a difference too - a bigger, rounder sound. A mic on the front head too (a large diaphram condenser - U47, KSM44, U87 etc) works great. Also try less damping against the batter head but a weight sitting on a towel in the drum really helps tighten the bottom end. Contrary to popular belief you will increase the low end response by tightening the batter head. Also the front head can be pretty tight. Works great!!
Old 01-28-2001, 12:04 AM
Hsk Hsk is offline
Assuming the drum is skinned right, dampened right and tuned right. . . I get great results using 2 mics as follows:
1)Shure SM-91 (Boundry mic) sitting on the bottom of the kick shell (must be on top of any dampening blanket);
2) An EV RE-20 sitting half way up, a few inches off the inside shell back about 8 inches from the skin.
I record on separate tracks with no EQ or Compression. For Monitoring blend to taste thru a Bus and Aux with a bit of EQ and compression.
============== and the later if you wish =========
depending on the type of music. . . you can get crazy and bus the tracks to a couple of mono Auxes and set up with plugins such as:
1)Filter bank P4 + F2 + Waves R-Comp.
2)Amp Farm + Filter bank P4 + F2
You can use F2 to split the spectrum of the kick between the 2 auxes and balance things out with EQ, compression and distortion to get some pretty wild punch. . . Also I sometimes sneak in the Rectifier Plugin, set to alternate, on one of the Auxes to get a fake lower Octave to simply move a little more air (careful).
To think I used to do this on some projects projects 10 years ago with active cross-overs, tube pre-amps and a DBX sub-sonic processors. Now you can do it in 10 minutes and save it with your mix.
I love Plugins.
[This message has been edited by Hsk (edited January 28, 2001).]
Old 01-28-2001, 12:20 AM
dBHEAD dBHEAD is offline
I like the Electro-Voice ND868 inside the shell and pointed at the beater, no EQ. Then, an RE20 pointed at the shell with a pretty significant high frequency boost. It gives a nice, crisp THUD you can feel in the pit of your stomach.
Old 01-28-2001, 12:55 AM
bingo bingo is offline
Try this!
1. Use two microphones, condenser ones..
2. Put one mic on each side of the drum
head. same distance.
3. Flip the the phase on one of them.(either
with a phase shifted cable, or in your console).
A bit akward but worth trying
Be aware/ Bingo
Help with Kick Drum torquemada Tips & Tricks 13 11-05-2006 07:20 AM
its been posted before, but drum mic techniques arcarsenal 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 04-08-2003 12:34 AM
Kick drum eq? Help! Binary Boy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 10-18-2002 06:37 PM
Kick drum micing techniques Forrest77 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 08-06-2002 12:57 AM
Senheiser MD 421 or Shure Beta 52 for kick drum?r kick drum mic? H-man 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 11 08-16-2001 07:07 AM
