Avid Pro Audio Community |
I recorded some tracks from ADAT to PTle via optical cable and it seems that ADAT is playing at 48k.
When I'm playing back those same track in PT they seem to be slower cause internal sample rate is set up at 44.1k Now,I already transfered all 13 songs from ADAT to PT - can I just change internal sample rate to 48k and everything's gonna be OK? Thanks!!!!! |
ok - the easiest way to do this is to create a new session for each song. be sure to do this in the same folder as the original session file so you don't have to deal with the potential confusion of having multiple copies of the same audio files.
so, to begin: create a new session, select 48k as the sample rate and call it "song x 48" or something so that you can readily differentiate it from the 44.1k session. in the new session, click on the File Menu. select Import Tracks. locate the 44.1k session, highlight it and click Open. under Sample Rate Conversion Options, deselect Apply SRC. under Audio Media Options, select Refer to source media (where possible). under Source Tracks, select all the tracks you need to import. if necessary, check the Import Tempo/Meter Map box - this will import the tempo grid from the source session. click ok. the tracks will be imported into the 48k session without any sample rate conversion and will now play at the correct pitch. |
Hey,this works great!!!!!!!!!!
Thanks a million rate!!!! |
Thanks a million rate!!!! [img]images/icons/wink.gif[/img] [img]images/icons/wink.gif[/img] [img]images/icons/wink.gif[/img] [img]images/icons/smile.gif[/img] [img]images/icons/smile.gif[/img] [img]images/icons/smile.gif[/img] |
glad to be of help [img]images/icons/cool.gif[/img]
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| change sample rate? | RonInLA12 | Pro Tools M-Powered (Win) | 0 | 01-17-2013 06:25 PM |
| How to change sample rate? | yanncrusoe | Mbox, Mbox 2, Digi 001, Digi 002, 003 (Mac) | 5 | 07-21-2009 09:04 AM |
| Change Sample Rate? | kevinb511 | Mbox, Mbox 2, Digi 001, Digi 002, 003 (Win) | 0 | 08-10-2006 11:33 AM |
| can't change sample rate? | benderbro | Pro Tools TDM Systems (Mac) | 2 | 08-16-2002 05:40 AM |
| Can't change sample rate from 44.1 | jreid | Digidesign Hardware & Software | 2 | 10-26-2000 05:05 PM |
