Old 10-09-1999, 06:22 PM
rdpete rdpete is offline
Default mac vs. pc? I need help choosing!
I would like to run PT on a notebook. Is this
possible? Which would be better, a mac or a pc? I would really appreciate some help here.
Pros/Cons?
please help!
rdpete
Old 10-10-1999, 08:24 AM
noisefloor noisefloor is offline
Default Re: mac vs. pc? I need help choosing!
Well, the mac version has more features (at least in 4.3.2) and more plugins (although supposedly NT will start to catch up at some point). And there's a much bigger installed base for the mac platform. Both platforms have some third party apps that are platform exclusive, but not that many (but you can run pc apps on a mac via emulation).
Mike
Old 10-11-1999, 09:09 PM
music music is offline
MAC MAC MAC MAC MAC MAC MAC MAC MAC MAC MAC MAC MAC MAC MAC MAC MAC MAC MAC MAC MAC MAC MAC MAC MAC MAC MAC MAC MAC MAC.
PC GOOD FOR ....
NEVERMIND
Old 10-12-1999, 12:12 AM
ProTool1 ProTool1 is offline
Damnit! I've said it before, and I will say it again, and I will continue to fight the war against sh@#ty computers.
PC's SUCK! Mac Forever
Hope that helps.
Old 10-12-1999, 12:42 AM
Przemek Przemek is offline
I think that what will help more is the information that one cannot run PT on PC notebook (or maybe ?)
Przemek.
http://imaginatlh.com/91709
Old 10-14-1999, 09:20 PM
El Guapo El Guapo is offline
I think when you are getting into a sophisticated application which must run stable (as opposed to not really mattering if it crashes) you should be very conservative. Digi has been on on the Mac since Day 1. I use a Tan G3/ OS 8.3 and it is rock solid. Stay away from the bleeding edge and you will spend more time recording.
Old 10-14-1999, 10:07 PM
GROS GROS is offline
PC's are great for running office applications and s--t like that games e.t.c but for serious stuff like protools that require stability i would not recomend it.i guess i can say that because i have both mac and pc.
PC's really do suck
Old 10-31-1999, 08:26 PM
Stratman Stratman is offline
Do this same post on the Windows NT Digi board and compare the comments. If you don't care about having a lot of plug-ins and a stable OS for the next couple of years, then a PC should be just fine.
It's the computer's game we play when we decide to make music with it
Old 11-01-1999, 10:02 AM
tnie tnie is offline
The industry in more into Macs than PC unless your using an SGI or a Sun station. You'll have less trouble with a Mac and less set-up time. I work with both and for a Audio,Midi, Video...use a Mac;for office work use a PC.
Yes, look at both the Mac postings and the PC postings and compare problems and features and you'll see PC won't just be fine!!!!
Old 11-01-1999, 02:29 PM
Jonny Atack Jonny Atack is offline
I have 2 PCs (Pentium II 300mhz) and 2 Mac 9600/350s. Personally, I intensely dislike our PCs and they get used now only for office work, which they don't even do that well due to frequent hangs under Win98 and the snail speed. Our Mac 9600/350s are stable in comparison.
In audio, the pros and studios mostly use Macs for interface preference and stability reasons, while many amateurs use PCs because they are less expensive and there are many cheap cards and plugs, etc. Your choice.
www.capitolstudiosparis.com
Help choosing Mac Pro for HDX yazoo Post - Surround - Video 2 12-12-2012 08:56 AM
Need Help Choosing a Mac acq1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 01-02-2009 12:18 AM
Help Choosing MAC bcbonzo Pro Tools M-Powered (Mac) 12 12-16-2008 04:54 PM
Help!!..choosing a G-4 B-man 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 09-04-2002 11:13 PM
CHOOSING A MIC GRIP22 General Discussion 5 04-26-2001 08:35 AM
