Old 10-05-1999, 06:43 PM
asouter asouter is offline
Default Direct Connect
Does anyone know how exactly "Direct Connect" will work? Will it be implemented as a TDM plugin similar to MOTU's "Audio Tap" that takes all audio signals directed to the Sound Manager into the plugin which can then be inserted in any channel(s) of the mixer? Perhaps it will be embedded in PT 5.0, which will simply give the Sound Manager Output as an input Option in PT? Or maybe it will more closely resemble "Rewire" and bypass the Sound Manager completely? Any ideas? Digi? Will it be able to be used in a third party squencer running under DAE? Any hope in simply developing "Rewire" for DAE? Can/will it be posted for download before PT 5.0 ships if it does not specifically require 5.0? Ideally, my vote would be "Rewire" for DAE if direct connect will not work under a third party squencer.
Old 10-05-1999, 07:24 PM
Digi Engineering Digi Engineering is offline
Default Re: Direct Connect
Direct Connect is implemented as a plug-in that connects directly into TDM bypassing Sound Manager completely.
-Mike Rockwell
Old 10-05-1999, 09:20 PM
GPD GPD is offline
A plugin which is used in an insert in the mixing board as with normal plugins? Does this mean that it will work successfully in a third party squencer such as Digital Performer when running under DAE? Does this also mean then that the software synth needs to be rewritten specifically for Direct Connect?
Old 10-06-1999, 09:24 AM
Yes it acts as an insert so it should work with other DAE apps. Yes synths need to be specifically written to take advantage of it. As far as I know all of the major host synth vendors have beta versions of their applications already running on Direct Connect. Most of them showed this as AES.
-Mike Rockwell
Old 10-06-1999, 11:01 AM
GPD GPD is offline
Does direct connect support multiple channels or only a stereo pair? Is is possible to DL a copy of the plugin now before PT 5.0 to test in a third party squencer?
Old 10-09-1999, 11:17 AM
GPD GPD is offline
To the top.
Does DC support multiple channels?
Old 10-10-1999, 12:17 AM
Joris Vincken Joris Vincken is offline
Yes, I've seen a demo of DC and it does support multiple channels. If a synth has 8 outputs you can choose in DC between 4x2 channels. So if you make 4 stereo aux inputs in PT you can use 8 seperate outputs.
Direct Connect? RGrierson Pro Tools TDM Systems (Mac) 1 02-05-2002 09:58 AM
Anyone use Pro 52 and Direct connect? Blake Henderson 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 01-10-2002 03:39 PM
Direct-Connect BUG? Henrik Pro Tools TDM Systems (Mac) 16 11-29-2001 01:09 PM
Direct connect? Chompers 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-14-2001 08:42 AM
Direct Connect for NT? Echo studios Pro Tools TDM Systems (Win) 1 06-29-2000 03:25 PM
