Community Terms of Use
Google Search | Search Knowledge Base | Search Avid.com
Find Support | Pro Tools Support Videos | Support FAQ
Software Updates, Drivers, Manuals, Compatibility, Troubleshooting, etc. (Links)
Please post your message once only to the correct forum
Help us Help You - READ THIS Before Posting!
Pro Tools 11
Go Back   Avid Pro Audio Community > Legacy Products > Mbox, Mbox 2, Digi 001, Digi 002, 003 (Mac)
Old 06-23-2003, 08:47 PM
billy the kid billy the kid is offline
Default about the spdif toslink on the g5
How will these be able to be used? Are these similar to the adat toslink were i can send 8 tracks in at a time. If so where do i sign. Or is it just a stereo track.
What i want to know is can these be used to record multiple tracks at once? If so how many?
Old 06-23-2003, 08:59 PM
Slim Shady Slim Shady is offline
Default Re: about the spdif toslink on the g5
It is Optical S/PDIF only which is a 2 channel format, it's not ADAT compatible. Also, you won't be able to use it with protools at all, but if you use other coreaudio based applications I'm sure it will be selectable as an input.
Old 06-23-2003, 09:40 PM
The difference can be clarified.. there is no ADAT Toslink protocol.. Digi products like the 001 and 002 support both ADAT Lightpipe and SPDIF optical... which are 2 different digital protocols.. the Mac G5's have Digital Toslink SPDIF connectors(2 channels). Toslink is just the connector type, not the protocol.
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Old 06-23-2003, 11:22 PM
H E A D W E R K ' N H E A D W E R K ' N is offline
Apparently the Optical Out supports surround sound formats, but then of course Dolby Digital and DTS are simply matrixed stereo tracks, not 6 discrete channels. I don't suppose Apple will be realtime software Dolby encoding into MacOSX 10.3?
Also, the optical in supports externally clocked sources up to 96KHz, but internally only up to 48KHz, which is the ceiling on the optical out too. Bit weird. I was kinda hoping Apple would duplicate what the SGI Octanes have had for years (ie. a pair of TOSLINKs supporting ADAT and S/PDIF.
'You're just mad because there's no clock in your hat...'
Old 06-24-2003, 12:07 AM
Vaphoron Vaphoron is offline
I think the real question should be, what application are they expectiing to need surround sound for? The DVD player would be the only one that I could think of. That would be great if they added system sounds in surround. Right as you computer starts to crash there can be wacky sounds going all around you to drive you nuts.
- Jason
Old 06-24-2003, 06:01 AM
espron espron is offline
<font size="2" face="Verdana, Arial">Actually, dolby digital IS 6 discrete channels, but they are all encoded into a single AC-3 stream which can be transferred using a single optical or coaxial spdif connection.
Espen
IMDB
003 and TOSLINK Roulette Records Mbox, Mbox 2, Digi 001, Digi 002, 003 (Mac) 12 09-22-2011 10:08 AM
Mac Pro Toslink Output into SPDIF: Converter? j20056 Mbox, Mbox 2, Digi 001, Digi 002, 003 (Mac) 3 07-05-2009 06:04 PM
TOSLink cable Jeroen Wolff Mbox, Mbox 2, Digi 001, Digi 002, 003 (Win) 2 02-16-2007 07:27 AM
Useing both SPDIF (RCA+TOSLINK) at the same time!! molle Mbox, Mbox 2, Digi 001, Digi 002, 003 (Win) 0 11-27-2002 05:04 AM
24/96 over aes/ebu, toslink, spdif, adat dancexsample General Discussion 1 04-09-2001 06:06 AM
