Old 12-14-1999, 11:15 AM
hewins hewins is offline
Default Bounce To Disk/Export problems
I copied a 48kHz DAT into a Pro Tools session and I am trying to cut it up into tracks so I can subsequently burn a CD of the music. I am having trouble exporting a file that something like Adaptec Jam can understand. I end up getting files that load into Jam but will not play so I can listen to them before I make the CD. I also tried opening the files in SoundHack and I couldn't listen there either.
I set up regions for the intended CD tracks in Pro Tools and I tried selecting a region and doing "Bounce To Disk" (from the file menu) and also "Export as files" from the regions menu. None worked. I tried different resampling qualities (Good, Better, and Best) and that didn't change anything. I tried bouncing Sound Designer II, AIFF, and WAV files and that all didn't change the result. In addition, I exported the regoin list to the main audio files and that didn't work because Jam needs 44.1kHz and not 48kHz files.
I would appreciate any help that I can get.
Thanks
Dan Hewins
Old 12-14-1999, 05:38 PM
KingTor KingTor is offline
Default Re: Bounce To Disk/Export problems
in the middle of the 'bounce to disk' dialog box is an option to 'convert after bounce' -- select that and then click the 'settings' button and you should be given the option of changing the sample rate. also, make sure that the bit depth is set at 16bit because Jam won't take anything else.
Tor Kingdon, Chief Sound Guy
Hear Kitty Studiostwitterfacebook
Export vs Bounce to disk? lanstrad macOS 23 03-26-2013 03:02 PM
Bounce to disk vs export osroubek macOS 8 02-04-2011 03:46 PM
Skip bounce to disk to export?? Possible?? sebdj Pro Tools M-Powered (Win) 1 12-10-2008 12:34 PM
Export Files .. or Bounce to Disk??? Doogz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 03-02-2004 08:29 AM
bounce to disk vs. Export region as files abraxas Tips & Tricks 6 09-02-2001 05:09 AM
