Old 11-15-1999, 11:39 AM
smrp smrp is offline
Default Mid Side Miking Technique
A friend has a finalizer. He tracked an acoustic guitar using the MS technique and used his finalizer to decode it. I tried the same using "S1 MS" and got completely different results. Iwas very impressed with the finalizer and terribly unimpressed with S1.
Did I incorrectly assume that "S1 MS" has something to do with this miking technique? Or did I just do something wrong? I might like to use this in the future if I can get it to do what I want it to.
Please help.
Old 11-16-1999, 03:45 AM
RMD RMD is offline
Default Re: Mid Side Miking Technique
you can also decode the recording yourself in protools. record the wide card/centre information on track one. record the figure 8 pattern on track two. duplicate track two onto track three and place it 180 degrees out of phase with track two. pan track one to centre, 3 & 4 hard left and right. lo and behold...rematrixed MS. season to taste.
cheers,
robert
Old 11-16-1999, 07:00 AM
TDunn TDunn is offline
What is the Blumlein technique? Could you describe that for me? Thanks!
Old 11-16-1999, 09:03 AM
thanks for the tips! I think I'll try it again and see what happens.
Old 11-16-1999, 05:38 PM
fab fab is offline
I'm interested in the MS thing too.
2 questions:
1- can I compress the signals right after the mike pres, (and before decoding) through a stereo only compressor ( That's what I have on my tracking path)?
2-If my pres have a decoder built in (CML) do I need S1 on playback?
Thanks,
fab.
Old 11-16-1999, 08:33 PM
Natural Sound Natural Sound is offline
Hi all,
Excuse my potential ignorance here, but I was having an MS discussion with a collegue.
My thought was that MS is fake stereo at best. (there can be no information that is on the left side that is not on the right side) But basically you cover your butt with the center mic should the product ever get put into mono. (in which case the fig8 mic dissapears)
His arugment was that there IS a left and right signal due to certain timing and phase relationships between the center and fig8 mic.
I don't get it though.
clue me in gang.
Thomas Anthony
Natural Sound
Old 10-21-2005, 05:06 PM
Rock_Artist Rock_Artist is offline
It's based on the following data:
The Mono/Mid Microphone gets the "Center/Middle" so it should get a clear straight picture of the sound.
The Side Mic use figure of 8 (the mic is positioned to the sides so it gets the left & right into a single channel)
Now M is the same.
However
M+S = Left
M-S = Right
Because we change the phase we get 2 phase cancelations.
One for left & one for right.
So we actually encode stereo....
Just wanna do music,
RA.
Old 10-22-2005, 06:00 AM
Don Geppert Don Geppert is offline
TDunn .....
Blumlein Technique is a stereo recording process using 2 coincident bi-directional mics (figure 8 pattern) angled at 90º and as close together as possible. Otherwise stated, it is an X-Y technique using bi-directional mics instead of cardioid mics.
Music Industry Arts
Fanshawe College
MIA2@sympatico.ca
Old 10-22-2005, 07:03 AM
MS is an *equivalent* to XY stereo. It´s by no means "fake stereo". It offrers very precise localizations and you can control the stereo width *after* recording or during the recording.
XY and MS are directly convertible.
MS was used for ages to cut vinyl records. actually the grove on a record is MS stereo as well.
MS is the only 100% mono compatible mic setup. that´s why it´s very popular in film and tv audio.
the standard chennel setup is
channel 1: M
channel2: S
the figure of eight has to be facing left with the front to make the S1 work. otherwise you will reverse L/R as a result but the S1 offrers a channel flip on the inputs
frank.
Hi all,<BR>Excuse my potential ignorance here, but I was having an MS discussion with a collegue.<BR>My thought was that MS is fake stereo at best. (there can be no information that is on the left side that is not on the right side) But basically you cover your butt with the center mic should the product ever get put into mono. (in which case the fig8 mic dissapears)<BR>His arugment was that there IS a left and right signal due to certain timing and phase relationships between the center and fig8 mic. <BR>I don't get it though.<BR>clue me in gang.
PTHDn 12.8.2HD (OSX10.12.6), 8x8x8, MacPro 5,1 3.33Ghz 12-Core, BM DeckLink SDI, SYNC HD, all genlocked via AJA GEN10, 48GB RAM
Old 10-29-2005, 12:51 AM
Monte McGuire Monte McGuire is offline
Yes, it's not "fake" stereo, but the two channels obtained have nothing but amplitude differences to clue the listener into panning. I personally like spaced mike setups, especially something like an ORTF array that spaces the mikes equivalent to the spacing between the human ears. To me, "intensity only" mikings, to which MS, XY and Ambiphonics fall into, sound boring.
Of course, YMMV, and if you absolutely need strict mono compatibility, then intensity stereo is an easy way to guarantee no problems. However, techniques like ORTF don't generally fail miserably when summed to mono either. I think they're quite viable when mono compatibility is an issue yet they don't sound so boring and sterile in stereo.
Sometimes, widely spaced miking setups also work well since the mikes are spaced so widely that cancellations aren't so simple and easy to hear.
As always, do this stuff by ear. If you only have one shot to get it right, then do several mikings at once and sort it out at mixdown. Tracking lots of channels is really cheap today, and there's no rule that says you have to use a track only because you printed it.
Best of luck,
-monte-
Side-by-side configuration error peter5992 Pro Tools Software (Win) 15 05-18-2012 08:30 PM
can I use the Mbox2 side to side to an Omega Lexicon?? nastyartproduction 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 09-23-2010 06:46 PM
New: Lopes Stereo Miking Technique Alécio Costa Pro Tools TDM Systems (Mac) 9 02-14-2009 09:12 AM
Digi,Side by Side errors in event viewer with PT's HD 7.4? x9blade Pro Tools TDM Systems (Win) 8 12-15-2007 11:19 AM
Mid-Side Mic'ing (not the technique, the mic) Ryan Young 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 05-26-2006 03:04 AM
