Old 10-26-1999, 06:32 PM
ratz ratz is offline
Default using an analog compressor w/demo bounce
Is anyone using tube compressors with PT24 as explained below?
I understand that once in the 24 bit realm, the mix should stay in 24 bit until the end, which is what I have subscribed to. However, a partner of mine recently read that the "right" thing to do is to 1st bounce your mix to a 2 track 24 bit arrangment. Then send it out of PT24 to a quality tube compressor to give it the "desired" sound. Of course the "desired" sound has many definitions (the fat, warm, tube sound)
I realize this is an objective question, but I continue to hear strong opinions going both ways. My partner is convinced the tube compressor is the way to go. I am not.
I guess I am really just asking to get a feel for what everyone is doing out there.
Thanks
Old 10-26-1999, 11:11 PM
Kenny Gioia Kenny Gioia is offline
Default Re: using an analog compressor w/demo bounce
I may be confused but it sounds like you're doing the same thing by bouncing first and then Compressing.
Anyway I think it's better to compress as you're mixing. This way you can use the most compression while readjusting your mix for that compression.
A nice amount of compression can really screw up your mix if you weren't aware of what was happening.
The more compression you use when you mix the less likely you are to be disappointed when you hear your mix on the radio with the crazy compression they put on it.
I usually overcompress while I'm mixing and then I'll pull it back at the end to give give it some air.
Maybe even print a few different mixes for radio singles & album cuts.
Peace :•)
Old 10-26-1999, 11:16 PM
coaster coaster is offline
ratz- who cares what we do? don't get a feel for what people do. do YOUR thing. only YOU are right when it comes to what YOU do.
by the way, i, like your friend, enjoy a good smash at the bounce. (about -3 db at 1.1:1)
www.mp3.com/xtac
for the faint of goth
Just running demo of Softube Fet compressor, anyone for a bit of 1176? crizdee Pro Tools TDM Systems (Mac) 11 03-31-2009 04:42 PM
Can't open a .bin file. PSP master compressor demo crizdee Pro Tools TDM Systems (Mac) 3 05-17-2007 12:35 AM
Slightly Rude Compressor demo Media Man Pro Tools TDM Systems (Mac) 0 12-29-2005 07:15 AM
Demo - Slightly Rude Compressor stargazer Pro Tools TDM Systems (Mac) 7 09-15-2004 10:48 PM
Analog Compressor For Tracking Tobias Eichelberg Pro Tools TDM Systems (Mac) 20 12-10-2002 12:53 AM
