Old 01-11-2003, 10:03 PM
CCash CCash is offline
Default Strange problem using monitor outs and outs 1+2
I'm trying different patching and monitoring setups. To oversimplify the setup, I can narrow down that the problem happens when:
I connect the digi001 1+2 outs to a Berhinger 4 channel headphone amp, and then connect the 001 Monitor Outs to my powered monitors. To calibrate, I use the Signal Generator plug-in on a soloed stereo track, outputting 1kHz @ -18dBFS (my 0VU reference) to outs 1+2.
Even with all volume controls down on the 001 and the headphone amp, a not-so-quiet, very distorted signal of the 1kHz plays through my monitors.
If I pull either the digi001 1-2 or Monitor Outs, the problem goes away. If I patch the digi001 1-2 outs to various equipment other than the headphone amp, the level and amount of 1k signal I hear "bleeding" through the monitors changes. Patching the monitor outs into certain balanced equipment eliminates it completely, and it is worst with the Berhinger.
The inputs of the Berhinger Power-Play Headphone Amp are suppossed to be balanced. I am using balanced cables. Sounds to me like some kind of impedance loading deal, or some "forced feedback" type-thing.
Any electronics gurus have any ideas? I'm worried about this because I wonder how much distortion is creeping into the monitors with regular program. Hate this mystery crap...
Old 01-11-2003, 10:35 PM
Default Re: Strange problem using monitor outs and outs 1+2
Mystery solved (for the curious): The headphone amp has a "main out", which is a nice way to send your headphone mix down the line to another piece of gear. I had it connected to another cheapo amp,using unbalanced cables. When I pulled these or swapped them for balanced, the distorted 1k went away. Nice.
Digi002 rack main outs vs monitor outs studiojb 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 11-03-2012 07:46 AM
Problem with 002 main outs as well as head phone outs? wiseal1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 12-10-2009 11:36 AM
001.....Main Outs or Monitor Outs G. Klopfenstein 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 07-01-2004 08:07 PM
Digi Outs work fine---Logic not getting signal to outs Thou 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 08-29-2001 02:52 PM
How can I have the monitor outs and main outs to the same input? voxpitch 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 03-15-2001 09:16 AM
