Old 07-22-2002, 03:27 PM
Timothy72 Timothy72 is offline
Default Absynth okay. Absynth & Battery = Error.
So, I can Direct Connect to Absynth pretty well into LE on my G4. I can also Direct Connect to Battery. When I try to do both I get a DEA error...I think -10009, but I'm not sure.
Any special setup needed?
Old 07-22-2002, 04:11 PM
petter petter is offline
Default Re: Absynth okay. Absynth & Battery = Error.
I am not really sure, but I think you can not use more than one app at the time with DC....(?).
Old 07-22-2002, 05:00 PM
adonis adonis is offline
I hope thats not true...the only reason I switched over to a MAC was for direct connect. I wanted to sell some of my hardware and start using software...tell me it's not true [img]images/icons/frown.gif[/img]
AD
Old 07-22-2002, 05:09 PM
hmccabe hmccabe is offline
Make sure that the track you are using for the DC plug in has an input selected. I set mine to use one of the lightpipe inputs because I don't use them, but I believe a bus track would also work, just so long as the input isn't set to "none". Then you can select the correct DC plug in as an insert.
Old 07-23-2002, 06:16 AM
Anders Bech Cyber Farm Anders Bech Cyber Farm is offline
Be sure you have the latest version of both Battery and Absynth. And try updating your direct connect drivers:)
Old 07-23-2002, 06:58 AM
I have the latest Battery and Absynth versions. How do I know if I have the latest DC drivers? Where do I get them?
I think this is almost an order of operations problem. For example, when I open Absynth or Battery before PT, I get an error when I load PT. But if I open Abs or Batt after a PT session is already running, I don't get a problem. So, I think there is something similar I need to follow to get both to open successfully.
Absynth 4 with PT8? Majorek Virtual Instruments 3 03-19-2009 02:44 PM
Absynth and Battery - Good on Mbox 2Pro? thebeatfarmer Pro Tools M-Powered (Win) 0 05-17-2007 01:33 PM
Battery 3 / FM 8 / Absynth 4 : issues yet ? Aquarius Pro Tools TDM Systems (Mac) 5 10-20-2006 05:37 AM
absynth & pt j creasey 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 07-21-2003 01:03 AM
Absynth Help Severe 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 11-16-2001 07:55 AM
