Old 06-07-2002, 12:36 AM
bsjaco bsjaco is offline
Default Transferring files between protools/digital performer
Does anybody out there have experience transferring audio and/or midi back and forth between protools sessions and digital performer sessions? If so, please describe the process as I am getting ready to do a project across both platforms. Thanks...
B
halfmoonandthe7stars.com
Old 06-07-2002, 08:27 AM
DigiTechSupt's Avatar
Default Re: Transferring files between protools/digital performer
You can transfer MIDI data between both applications by importing and exporting Standard MIDI Files.
To transfer Audio data (including edits/playlists), from DP to PT, you will have to:
-Export the file in OMF file format
-Use OMF Tool or DigiTranslator (preferred) to convert the OMF file into a Pro Tools session.
To transfer Audio data (including edits/playlists), from PT to DP, you will have to:
-Use DigiTranslator to convert the session into an OMF file.
-Import the OMF file into DP.
Brent
Avid Audio Tech Support
Support FAQ
Old 06-07-2002, 08:50 AM
BagHun BagHun is offline
Brent's right, of course. But he fails to mention that you lose a lot of information (markers and layers of audio, for examples) in the transfer even using OMF.
The cheap way to transfer audio is to make each track one audio file by merging soundbites in DP or consolidating audio in PT. Also, make sure all the tracks have the same starting point. Then you can just use the import function of each application to get back and forth, since all the audio files are SDII.
Old 06-07-2002, 09:55 AM
shaggy shaggy is offline
Both later versions of Vision and DP took out the 'import midi' menu.
This was the stupidest move ever! What were they thinking?
Anyway, convert the MIDI files to 'Z' type. Pro Tools does not accept 'multi' midi files (you know the type with one track and many different instruments/midi channels.
If no tempo maps. Just open the standard MIDI file with Pro Tools, and at least you got your tempo and grid. Then import audio.
You want to 'consolidate' audio regions before you export. The soundbite 'export' submenu option does that automatically in DP?
Then follow the BagHun technique. Do it the quick & dirty way...
.02 fleas
"The original nipper" Throw me a bone (Telefunken DI is ok too)
Old 10-25-2010, 04:32 PM
Bryan Cook Bryan Cook is offline
so the short answer is you have to put DP takes onto separate and visible tracks, export the OMF, and then condense the tracks into playlists in PT? zoinks.
Digital Performer 5 files ducada Pro Tools Software (Mac) 15 02-15-2014 06:01 AM
do I have Digital Performer files or not? c-post Pro Tools TDM Systems (Mac) 1 09-27-2006 10:39 AM
Protools TDM files to Powerbook Digital Performer fifty8th1 Pro Tools TDM Systems (Mac) 1 10-04-2005 09:57 AM
Transferring WAVE files to a digital recorder-Help Mistermac 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 06-27-2005 01:03 PM
OMF Files Digital Performer rseely 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-09-2002 10:45 AM
