Old 11-19-2001, 03:56 PM
dkrausz dkrausz is offline
Default Signal Path Question/Master Fader
When setting up plugs on the master fader for a final bounce. Which way does the mix bus process them? For example, if I had a limiter, EQ and reverb, in that order from top to bottom, does that mean that the signal path gets to the verb last getting limited and EQ’ed first or does it all sort of happen at once?
Sorry, maybe a stupid question... could someone please clarify?
dk
http://homepage.mac.com/dkrausz
Old 11-19-2001, 10:06 PM
BFSfullsail BFSfullsail is offline
Default Re: Signal Path Question/Master Fader
it goes from top to bottom
G4 533
512 MB SDRAM
15GB Mac drive
40GB Audio drive
60GB Audio drive
MTP AV
VC-8
Thank you Wave Digital!
Old 11-20-2001, 04:57 AM
Thanks.
dk
Im getting a much stronger signal on my left side of Master Fader while Im in record shamanrock Windows 0 04-12-2012 10:56 PM
Basic Gain Structure Fader/Master Fader Question acmost Pro Tools TDM Systems (Mac) 1 05-16-2011 05:36 AM
No Signal on Master Fader 002 during Low Latency? goom 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 02-04-2006 10:44 PM
OT: signal path "bypass" question Dopamine Pro Tools TDM Systems (Mac) 2 08-15-2004 07:46 PM
Signal path with the PRE I/O - how much in TDM? (Newbie question.) ekuehnl Pro Tools TDM Systems (Mac) 4 02-26-2002 12:04 AM
