Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | Duet & Pro Tools | Quartet
Old 08-28-2020, 03:45 PM
aadvance aadvance is offline
Default Catalina Drivers for Avid Quartet?
I have the Avid-branded (black) Quartet connected to my dual-boot (Mojave/Catalina) trash-can Mac Pro. Currently my PT install is 2019.12U on the Mojave (10.14.6) side only which I use for editing and mixing, but just updated my Avid account to try 2020.5 on the Catalina (10.15.6) side, which I use for composing in Logic before switching over. My Quartet has been my interface since the beginning, and up till now hasn't had any issues. But whenever I tried to install the PT IO Control app it didn't take, in that I'd launch it but it wouldn't see the Quartet as a device to connect with. Multiple reinstalls gave the same result. But now since those installs attempts, whenever my computer goes to "sleep" the interface basically shuts down, causing a noticeable "pop" in my monitors (not loud but still noticeable) when it sleeps or wakes from sleep that wasn't there before my attempting the Control Panel install. This never happens on the Mojave side.
I guess my question is, should I even go forward with adding PT to my Catalina partition? My current situation is still working fine, but for convenience I was hoping to fully move to Catalina now that I've seen first-hand that 2020.5 on Catalina can finally handle the video-related stuff I need for work. Bonus points if anyone can help me detect that popping issue...
Old 08-28-2020, 03:57 PM
Default Re: Catalina Drivers for Avid Quartet?
Didn't mention this before, re: pop in monitors. In order to "fully" use my Quartet in Logic on the Catalina side (mute/solo/record, etc.) I had to install EuControl. After I uninstalled IO Control Panel I didn't uninstall EuControl, could that be the source? But why would it pop in Catalina and not in Mojave if both sides have EuControl installed? Oh, the confusion...
Old 08-29-2020, 08:06 AM
Southsidemusic's Avatar
The first thing to do is turn OFF all sleep functions as that will just make the quartet behave like you describe. PT and other DAW’s and interfaces doesn’t like sleep features and should never ever be initiated on a Music computer
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 12-29-2020, 12:14 PM
You are correct, my friend. I assumed I just had the display sleep function, but apparently "put hard disks to sleep when possible" option was also enabled in sys prefs; turning this off eliminated the popping.
Also, just out of curiosity, a few days ago I tried installing PT IO Control again after updated my Catalina drive to 10.15.7, and it worked like a champ! This is huge for me since I can now assign my headphones to a different output from my mains for VO work.
Now all I need is for Avid to fix the "bounce to QT" bug for Catalina and I'll be fully on-board...
Old 12-29-2020, 04:25 PM
Thanks for letting is know
Have a great week and a Really Happy New Covid free 2021.
Best Regards
Christopher
#thestruggleisreal
WEBHOME
SC48 recording Drivers for Catalina Pantson VENUE Live Sound Systems 7 02-09-2021 04:25 PM
Mojave-Compatible PT Duet/Quartet drivers polarm Pro Tools | Duet & Pro Tools | Quartet 0 10-04-2019 04:58 PM
Sierra Quartet Mac Drivers Not Listed Prentiss Carr Pro Tools | Duet & Pro Tools | Quartet 7 10-29-2016 11:16 AM
New drivers for Quartet+Duet 2 VRW Pro Tools | Duet & Pro Tools | Quartet 0 10-17-2014 01:23 PM
