Old 08-05-2020, 04:35 PM
ScottyD ScottyD is offline
Default Artist Mix across a subnet? VPN?
I'm doing a little bit of science to see if I can first get an Artist Mix to work across a subnet and ideally over a VPN connection. I know an Artist Mix typically needs to be on the same subnet to work. This is for a remote workflow I'm trying to suss out.
Anyone get this kind of thing working? Thoughts?
TIA,
Scotty D
Old 08-05-2020, 09:46 PM
robertg robertg is offline
Default Re: Artist Mix across a subnet? VPN?
TIA,
Scotty D
It's just a standard ethernet TCP/IP device meaning if you have the proper routing in place, like can the two subnets see each other, it should probably work. Unless there is some broadcast type of traffic that it relies on, local broadcasts are typically not forwarded to other networks.
Old 08-06-2020, 08:45 AM
EddieJones's Avatar
Pretty sure this won't work, sorry.
Old 08-06-2020, 03:04 PM
@EddieJones - have you tried it? I'm thinking that we just need to set the Artist Mix up with a static IP and poke a hole in the firewall for Bonjour (EuCon Discovery) to the other subnet. It might not work, but it's worth a try.
Can I change Eucon Layouts with an Artist Mix or Artist Transport? amathie Artist Series 10 09-21-2017 07:29 PM
Artist Chat window in Avid Artist Community taylor4814 Pro Tools 2018 0 01-25-2017 06:30 AM
2 avid artist mixes and one artist control V2 for sale Brandonx1 Buy & Sell 2 03-21-2016 09:55 PM
HDX1, 8x8x8 I/O, Artist Mix, Artist Transport, AAX DSP plugs ArKay99 Buy & Sell 8 03-22-2015 01:12 PM
Touching Artist Transport Freezes Up Artist Control in Logic sonofmack Artist Series 1 03-13-2013 08:22 PM
