Go Back   Avid Pro Audio Community > Legacy Products > RTAS & TDM Plug-ins
Old 05-26-2020, 12:52 PM
Mattafact Mattafact is offline
Default Avid Eleven TDM issues
I recently upgraded my PT HD Accel from 9 to 10 on Snow Leopard and my Eleven worked as a DSP plugin.
I then upgraded from Snow Leopard to Mountain Lion and ran basically every Eleven installer I could find and it will only work as a native plugin. I tried trashing the prefs and no change.
I kept my snow leopard disk but I'd rather use a newer OS if possible.
Breakthru Recording
www.myspace.com/breakthrurecording
Old 05-26-2020, 02:00 PM
crizdee's Avatar
crizdee crizdee is offline
Default Re: Avid Eleven TDM issues
Have you tried simply copying the plugin from the Snow Leopard plugins folder into the Mountain Lion folder. Library, Application support, Digidesign, plugins. No reason why this shouldn't work really.
If you have used a recent installer it could be the AAX installer which would only be native.
Chris
Producer, Engineer,
www.ukmastering.com
Old 05-26-2020, 02:06 PM
Originally Posted by crizdee View Post
Chris
I'll give that a shot. Should have thought of that. Thanks!
Breakthru Recording
Old 05-26-2020, 02:46 PM
That worked. I'm so confused but glad it's working.
I'm getting kinda tired of spending so much time messing with this ancient stuff. HDX and Mohave is sounding pretty good right about now.
Breakthru Recording
Eleven Rack #2 issues BurbankGuy Eleven Rack 5 03-05-2019 09:47 AM
Eleven Rack Issues Kilboot Eleven Rack 6 03-08-2016 08:37 AM
Issues with Eleven Rack and PT 11 JacksonRR1 Eleven Rack 12 01-07-2015 08:56 PM
Eleven Rack / Avid is not producing anymore Eleven Racks is that true or false? Rongpat Eleven Rack 8 02-11-2014 07:42 AM
Issues with Eleven Rack. Again. BrandonFrisby 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 06-29-2010 03:30 PM
