Old 05-16-2020, 01:56 AM
koka koka is offline
Default PT 2020.3 problem with Finder Mojave
HI to All
Protools Ultimate 2020.3 almost every time starts with grayed menu items.
Cant select open Session all file menus grayed out?
After selecting anything from Setup menu everything back to normal?
Anybody who can point whats the problem?
Old 05-16-2020, 02:51 AM
JFreak's Avatar
JFreak JFreak is offline
Default Re: PT 2020.3 problem with Finder Mojave
Can you tell something more about your Setup menu experience.. what is there before you "select anything" and what is it that you select?
Janne
Old 05-16-2020, 02:52 AM
JFreak's Avatar
Also what Mojave version are you using?
Janne
Old 05-16-2020, 08:19 AM
Mojave 10.14.6
Macpro 5.1
Anything selected in Setup menu bring back File menu and other menus usable.
See pictures
File Type: jpg Screen Shot 2020-05-16 at 5.18.11 PM.jpg (14.3 KB, 0 views)
File Type: jpg Screen Shot 2020-05-16 at 5.17.53 PM.jpg (20.6 KB, 0 views)
Old 05-16-2020, 08:24 AM
JFreak's Avatar
First I see this. Maybe trashing preferences would help resetting something?
Janne
Old 05-16-2020, 02:18 PM
Trashing preferences solved issue just for a while.
After 3 or 4 restartarts of Protools issue comes again.
Strange...
Old 05-16-2020, 02:51 PM
JFreak's Avatar
Have you already started a support case with Avid? This sounds so random they need to know about it.
Janne
Old 05-19-2020, 12:38 PM
Hi again
I found the solution !
When I installed Avid Link again Menus comes back.
This is a little present from Avid ,when you decide to uninstall Avid Link.
Old 05-19-2020, 01:20 PM
Originally Posted by koka View Post
Hi again
The first thing I do on every install is uninstall Avid Link and Cloud Services. I am running 2020.3 on Mojave 10.14.6 and don't have the same issues. So I don't think uninstalling Avid Link (using Avid's uninstaller) is the issue.
Scott Gatteño
Old 05-20-2020, 09:19 AM
What else can be?
Pro Tools 2020 with Mojave/reinstatement plan? Thenewexhibit Pro Tools 2020 9 05-04-2020 02:44 PM
Pro Tools (2020.3) on MacBook Air 2020 compatibility pellekuipers Pro Tools 2020 1 04-04-2020 08:01 AM
PT 2020 to require Mojave and drop High Sierra support? XJENSEN Pro Tools 2019 10 03-28-2020 11:54 AM
New Avid Link 2020.1 - launched today 1/16/2020 marianna Licensing & Accounts 8 01-16-2020 11:43 PM
PT 2019.5 + Mojave fresh install: Velvet problem Detlef Brockmann Pro Tools 2019 0 05-18-2019 06:50 AM
